edit: solved
Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
First of all I would like to thank oman for the support and great fw.
I have an mxiii 2gb version. My problem is that every 2-3 days the clock and date of my device turns back to 1970 and I have to reset it to the correct one. Does this happen to all devices? I am not sure if the electricity or internet connection went down. Isn't there an internal battery on the device that keeps the clock up to date?
My second problem is the remote control-airmouse I use (mele f10 deluxe) has a game mode that doesn't work on my device. It works only on mele devices. If it is possible I would love to have full support for mele f10 deluxe on the next fw.
Thank you very much tv box lovers!
I'd like to add some more information. The issue described below also exist with Kodi beta1 and channel preview position is not centered if you zap to channel (stream) encoded with h264, but mpeg2 is ok. And later it gets worse. When you continue switching some more channels encoded with h264 after that you'll get only audio and black screen. This issue disappears if I disable amcodec acceleration in XBMC video settings. Some people reported the same problem with Minix X8-H 9-2 beta firmware to XBMC and Minix forums:
Received response:Deactivate amlogic codec in settings and try video playback again. If you see the video screen now, this should be a firmware issue.
This special problem will be solved with next 002 release - amlogic has already adjusted this issue.
Originally posted by lawin1 View PostJust updated firmware on Tronsmart s89 from 104k to the latest 109k. Launched XBMC 13.2 and enabled Live TV with IPTV Simple client. And now XBMC Live TV channel preview position is not centered as described in this post: http://www.freaktab.com/showthread.p...l=1#post213799
[ATTACH=CONFIG]8535[/ATTACH]
Before updating to 109k, I had XBMC 13.2 also but from official XBMC site and everything was ok. Is this known bug in included XBMC and how to deal with this problem?
Re: Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Originally posted by kiziumiziu1981 View Post
who made this fimware ?
There are currently 4269 users online. 1 members and 4268 guests.
