Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Originally posted by serunting View Posthai i'm on 1074k firmware.
i dont want to upgrade to the latest fw, is there any method to make the box support the ps3/sixaxis controller ?
thanks
The firmware not the issue its the app itself.Mk802IV Neomode 1.9a original rom 720p
Originally posted by Magnus33 View PostHighly unlikely since that app hasn't been updated in over a year.
110k4 - issues
so I downloaded this 110k4 firmware update for the 1GB version AP6181 from here http://androidpc.es/blog/2014/11/18/...2-mxiii-110k4/
so far I have experienced Netflix jerkiness playback although internet connection is good, and it has buffered. XBMC streaming is ok, but if you turn on live tv simple client, while loading channels can freeze preview window for the channels is offside also.
anyone experience these issues?
now I want to downgrade back to 108k4 AP6181 1GB, but I can't find the file for that, all are for rtl8188 wifi module.
What is your experience with 109k4 and 110k4 ???
Originally posted by Finless View PostActually it is a AML Bluetooth driver/stack issue. AML knows about it but has not done anything about it yet.
Originally posted by NYR94 View PostAnyone using an optical cable for audio ? When I was on 108k4 it worked fine but with 109k4 it doesn't work. I tried auto detect and manual to pcm. Using an MXIII 2G
Dolby Digital 5.1 *confirmed*... I still have to find a DTS Source to test though. But, I can't imagine why it shouldn't work. Given that we're talking about RAW Bit Data here.
In the case that I'm using a DD5.1 & DTS Decoder to do that lifting. So your Setup may vary.
Is there any chance in Hell that we 1G/8G MXIII Owners might get to see some kind USB BlueTooth Dongle Driver support? Seeing as this version, of the Device has probably jipped a good many of us out of it... I'm not blaming anyone but, the Fleabay Seller(s) that had... Let us say mirrored the Specs for the 2G/8G Version, and left it at that... Though to be fair it was tagged as only being a 1G/8G Device.... Had I only known before hand....
One other thing... A bit of a Bug rally... Though I finally was able to solve One little mystery tonight. As in what the irserver.apk does.
Apparently its the backend service to the Smart iRemote (Google Playstore), Frontend.
Problem is, like many have already posted in the Review Section (Myself included!), It doesn't seem to work very well. When it comes to synching (or pairing), it up with said Device. If I manually input my IP Address into it... It works. As soon as I back out of the Program.. Or I restart it I have to re-enter that same IP Address into it again!
Any chance that you can:
a) Fix the Pairing problem?
b) Fix it so that we don't have to keep re-pairing this Virtual Remote to Said Device every time we'd wish to use it... (i.e. Keyboard Typing!!)
Thanks!Last edited by Ichijoe; 22 November 2014, 04:20.
Originally posted by oman View PostFW Release->
The latest:
Upgrade By USB: Download Here(108k4)
Upgrade By TF card:Download Here(108k4)
S82 / MXIII(2G)->
Upgrade by TF card:Download Here(109k4)
MXIII(1G & AP6181 WIFI)->
109k4->
1.Optimization Power Consumption.
2.Improve stability issue When auto reboot,auto suspend,Monkey test,AV file continue playing.
3.Add protocol: UDP ,RTP , MMS ...
4.Update NAND/EMMC driver.
5.Fix some Wi-Fi throughput problem.
6.Support Antutu videobench apk.
7.Optimization display effect for HDMI.
8.Support new feature DRM,Playready L1/L3,Widewine.
9.Add Secure OS.
10.Visit America websit netflix and youtube smoothly.
11.Strengthen encoder stability.
12.Change the Mxplayer to normal version;
13.Update xbmc to Gotham 13.2,and open some nodes' authority,so you can install any version of xbmc;
14.Make the physic power-key to be suspend/resume working by short press,and long press (5s) to shutdown;
15.Remove the Popup notification when xbmc/Mxplayer/... been ran at the first time;
16. Add an Icon to show/hide Status Bar;
17.Support Hausbell Mmini i8 and Rii Mini H7 air-mouse;
18. Make some portrait APPs to be showed to landscape,such as Antutu;
19.Fix issue:the A/V Async for MPEG2;
20. Fix issue:it may auto-wakeup when in suspend state;
21.Fix issue:the usb port may lose efficacy after resume;
22. Fix issue:no sound for Notification;
23. Improve some parts of MBXLanucher;
24.Fix issue:Google Calendar/People cant sync.
108K4->
1.Add 1080P24Hz support;
2.Support for NTFS/CIFS; --Offered by wasser
3.Change Input method to Latin,and remote can use;
4.Update Play Store;
5.Support for Mele F10 air-mouse; --Pulled from Bob's FW
6.Support for Xbox/PS3; --Offered by Bob
7.Change method of Root access; --Offered by leolas
8.Add kill-recent-task function; --Offered by daemonium
9.Update xbmc to Gotham 13.1,fix 4k playback and 2160P/720P HDMI display issue; --THX stane
10.Add remote function in Recovery Mode;--THX leolas
11.Adjust MBXLauncher,add Yahoo wether and Clean-Memory function,fix slow animation issue;
12.Fix issue->Power-key of Remote might lead to reboot;
13.Improve small probable of blurred screen.
107k4->
1.Add for CPBLTV live stream;
2.Decoding Dts/Dolby for S802;
3.Add suspend and Power-off function by Remote or power button from Status Bar;
4.Add root access permission.
106k4->
1.Enhance system stability;
2.It can flash Ethernet MAC;
3.Enhance the power of 4k video decoding;
4.Fix issue of 1080i video playing.
105k4->
1.Fix some LiveTV apk can't be ok;
2.Optimize Thermal control;
3.Optimize HDMI/AV;
4.Optimeze Launcher/Settings,use only 1080P UI;
5.Fix video burning test fail;
6.Support secure OS function;
7.Update NAND driver;
8.Support APK installation to external SD.
103k4->
1.Better xbmc for playing 4k video;
2.6210_8G compatible with 6330_16G,to be the same FW;
3.Add PPPoE;
4.Adjust thermal control,Special for Antutu;
5.Adjust HDMI signal to more TV compatible;
102k4->
1.Better xbmc,no async between audio and video ;
2.Fix 5G wifi compatibility;
3.Better for Antutu benchmark;
4.S802/S802B/S802H are all compatible;
5.Other little tweaking.
TOOLs:
Update tools by USB: USB_Burning_Tool_v2.0.1_x86
How to upgrade FW By TF card:
1.Unzip the zip/rar file,and copy 3 files(105k4.zip,recovery.img,factory_update_param. aml) to TF card Root directory;
2.Plug in the TF card and Power line,then pressing the button in the AV hole,then press power button,then release button in the AV hole.
3.OK,it will be into update process.
i want to ask you im noob i have m8 s802 k200
dose this work with my tv box m8 s802 model number is k200
and is it safe ?
Originally posted by Ichijoe View PostOn 109k4 (1G/8G MXIII), and Tosslink Optical Out is working fine with my Creative DDTS-100 Decoder. When set to use SPDIF-Out! I think you also need to turn the Auto Detect off, or else it defaults to PCM LPCM (HDMI).Maybe thats not a good test. Have to find a movie that has good sound effects for the rear.
There are currently 4119 users online. 0 members and 4119 guests.
