Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beel...
Originally posted by milanov007 View PostActually the stock 108k4 on the MXIII 1 GB with AP6181 played Netflix perfectly, but the issue is… this firmware is nowhere to be found now. I regret losing it.
P.S Check link below if it solves your problem but check your compatibility first.
Sent from my iPad using TapatalkLast edited by dlangejc; 27 November 2014, 22:06.
Originally posted by milanov007 View PostI have the 1G MXIII running the latest 110k4 and Netflix uruns grainy, and choppy.
Who else experiences this issue?
Any fix around this problem??
2) Did you try updating the Netflix.apk? Google Play has an Update!! Perhaps that Update... May cure your ills?
Originally posted by Ichijoe View Post1) Why?! 110k4 is ONLY meant for the S82 (2G/8G MXIII), the only "change" was to the broken Bluetooth stack on those Devices!
http://androidpc.es/blog/2014/11/18/firmware-oficial-para-tv-box-quad-core-s802-mxiii-110k4/
and also here http://chinagadgetsreviews.blogspot.ro/2014/11/download-latest-android-kitkat-442_48.html
Yes there is an update for Netflix in the googleplay store…and I tried it, but did not fix anything… same shiznits. This is a definite firmware issue, I hope there is a fix soon, and if there is a fix, will it be posted here???Last edited by milanov007; 28 November 2014, 00:34.
I love the MXIII android box... don’t get me wrong. I wish however, that a couple of issues were fixed and those are:
- Netflix to play smooth and clear at 1080p
- The preview window in XBMC when on LIVE TV to be centered, and not off to the side (visible only 20% currently)
Too bad no one was able to jailbreak the Apple TV 3; that would have made the Apple TV 3 a great box for XBMC and Netflix combined. I love the Netflix layout on the apple tv, and xbmc is awesome with the simple lightweight quality button apple remote.
Which makes me think???... is there a USB type of remote like the Apple TV remote that can be applied to the MXIII TV Box? …or is there a way to make the OEM Apple TV remote work with MXIII ?
Any input guys???Last edited by milanov007; 28 November 2014, 00:34.
THIS IS GREAT LOOKING REMOTE AND THE SHITTIEST REMOTE EVER AT THESAME TIME! I DON'T THINK THE BUTTONS CAN POSSIBLE BE ANY WORST!
After using it for 1 week, I developed pain in my thumbs. Does anyone know a good button remote, similar to the Apple TV remote, which can work with MXIII tv box? Something with a nice feel yet compact? Not too many buttons either.
Originally posted by milanov007 View PostTHIS IS GREAT LOOKING REMOTE AND THE SHITTIEST REMOTE EVER AT THESAME TIME! I DON'T THINK THE BUTTONS CAN POSSIBLE BE ANY WORST!
Originally posted by milanov007 View PostThere were two websites that posted the 110k4 update for the 1Gversion with AP6181, so it was not meant for just the 2G version.
Might be a codec issue, might be an Amlogic issue - The older SDK's doesn't suffer from this problem, would be nice if someone will let us know that this is being addressed.
Originally posted by milanov007 View PostI love the MXIII android box... don’t get me wrong. I wish however, that a couple of issues were fixed and those are:
Any input guys???
Kodi 14 alpha1 https://cloud.mail.ru/public/85e6f5d...rmeabi-v7a.apk
or
Kodi 14 alpha3 https://cloud.mail.ru/public/c671ee0...a3-armeabi.apk
You can even use XBMC 13 (Gotham) skins on Kodi 14 alpha1!
Originally posted by lawin1 View PostAs a temporal solution to the Live TV preview window is off to the side problem you may try
or
hey lawin1thanks for the tips. Funny thing is that Itried these avenues also, I installed and unistalled and installed another versions of XBMC and that didn't help. I tried kodi alpha 1 and alpha 3 and tried gotham 13.0, 13.1, 13.2 and also I tried IPTV simple client 2 - but the issue remains. I don't get it. At one point I didn’t want to even use the awesomeness of this LIVE TV feature.
I am sure it is a firmware issue and most likely this is the reason the Netflix performs bad.
To be hones I secretly miss my old Apple TV 2 when it comes to the issues I have to face now with this MX III box. Sorry to say this guys, but I am sure most of you who had an Apple TV 2 agree with me on this point. The only thing I hated on the Apple TV 2 is that when it gets overloaded buffering or the temp goes up (whatever the trigger was).... it restarts on its own. That drove me CRAZY. That was the reason that made me switch to this android box.
For most of the part the MX III is good, when it comes to streaming movies on XBMC... but that’s it for the moment. Sorry if it seems like I look at things negative but that’s my overall experience at this point.
1. Extract to a root of SD card (FAT32 formatted) 3 files: recovery.img, factory_update_param.aml, k200-ota-20140917.zip (do not extract this zip file!)
2. Insert SD card.
3. Go to SETTINGS -> Other -> System Update
4. Check "Wipe Data" and "Wipe Media", click "Update" button, select k200-ota-20140917.zip file, click "Update" button again.
Originally posted by lawin1 View PostStrange. I'm on 109k4 firmware + Kodi 14 alpha1 and the Live TV preview window is exactly where it should be. Of course I had to uninstall XBMC included in 109k4 because of the Live TV preview window is off to the side problem which you did mention in your posts. Did you factory reset your device after firmware installation? And I suggest you to restrain from installing modified "IPTV simple client 2". Use only default IPTV Simple addon. Perhaps you should try once more, install 109k4 firmware using SD card method: http://www.freaktab.com/showthread.p...l=1#post191438
2. Insert SD card.
2. Insert SD card.
To be honest I'm getting more into Show Box at the moment. Now if I could only find a decent Player. MX Player is going downhill FAST! BSPlayer is somewhat better, but with even more annoying Ads. I'll see if VLC could do a better job of it in a bit.
Oh One thing to NOTE about Format wiping and, why you might want to reconsider doing it...
It seems that since last August WITHOUT ACTUALLY TELLING ANYONE!! Google has again changed its "Policy" on how many "Devices" One may "Deactivate" with-in the space of One Year... AFAIK it used to be near unlimited... Or so I had thought. Till I discovered about Five "Different" MXB MXB M82 Device's in my "Device List"... Needless to say I only have the One MXIII, and not Five! But having recently made some room (About a Month or ago needing to set up a relatives Phablet). It seems that I had already used up my block of Four Deactivation's, and was barred from removing anymore...
Why this matters... When you Factory Reset / Cache Wipe your not just resetting the Device to Stock... (DUH!), you are also generating a whole new Android ID as well! Apparently its this Android ID, that gets counted as a New Device every time you log into Play Music, thus increasing the Device Count on GMusic...
So if you like GMusic you should think twice about forking 'round with these ROMs. Barring that don't use GMusic on the MXIII (Android TV Box), until your sure your not gonna be playing with it every other Week!
This is just a whole new reason on top of every other reason WHY WE NEED CWM Recovery for the M82/S82 for Nandroid Backups! (e.g. being able to retain identical Android ID's)...
There are currently 2497 users online. 1 members and 2496 guests.
