Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
RK3288 Devices
- Overview BOX (LINK !)
Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beel...
Got sum issues here trying to update. Currently on 108K4 which was flashed with the AML USB tool. Now trying pin hole method to upgrade to 111K4.
Can't seem to get into recovery and if it does the Android guy falls over.
Can see the files on the SD card and I have the correct 3 files. Tried formatting SD and used another SD card but the same result. Tried with a reboot recovery app but the same result.
Any ideas?
Is this the correct recovery? please see attachment 😄
Originally posted by dlangejc View PostGot sum issues here trying to update. Currently on 108K4 which was flashed with the AML USB tool. Now trying pin hole method to upgrade to 111K4.
Any ideas?
[ATTACH]9392[/ATTACH]
Originally posted by vel2000 View PostWhat about the video (codec) quality?
Any improvements, or at least any other noticeable changes?
Playback before often had audio/video sunc issues with audio lagging behind the video.
Not to mention playback of some media just looked crappy.
I yet to see either of those problems now and netflixs seemed to pop straight into focus.
Not sure what res netflicks is playing at but this firmware is a must upgrade.Mk802IV Neomode 1.9a original rom 720p
Originally posted by dlangejc View Post@Magnus33 Which version were you on prior to 111k4? Trying to establish why I can't upgrade ... Downloaded the files twice already 😝
Are you using everything from the download or factory/par files from older releases?Mk802IV Neomode 1.9a original rom 720p
@Magnus33 I am using everything from the new download. The 3 files, recovery, Amlogic parameter file and the zip file.
factory_update_param.aml
recovery.img
k200-ota-20141218.zip
Edit: Going to download the img file for 109K4 and flash and see if it makes a difference.Last edited by dlangejc; 23 December 2014, 19:57.
Originally posted by dlangejc View Post@Magnus33 I am using everything from the new download. The 3 files, recovery, Amlogic parameter file and the zip file.
recovery.img
There also updating from the update app if the button push method doesn't work.Mk802IV Neomode 1.9a original rom 720p
I think there is something wrong with the Recovery on the NAND. OTG doesn't pickup via the AML burning tool. SD doesn't work, tried a factory reset and cannot get past the Google TV loader, it boots into Android yet no indication that any apps have been removed. WTF!
Apps are all there tried to reboot to recovery via Petrus reboot app to load fw from SD but just get the Google TV stock boot loader. At least it works but no recovery console it seems. Even took the box apart to make sure everything is making contact. On a positive note my OTG port feels rock hard, lol and the SDCard now slots in like it should, lmfao 😄 I'll carry on tommorow, thanks for the suggestions guys, you rock as usual.
There was a bad recovery that came out. Minix has it on the X8H Plus as well.
When I do my ROM I will look into it. Bottom line you will need a good recovery on SDcard.
Originally posted by Finless View PostThere was a bad recovery that came out. Minix has it on the X8H Plus as well.
There are currently 2985 users online. 0 members and 2985 guests.
