Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
RK3288 Devices
- Overview BOX (LINK !)
Ah there .. thanks guys :-)
Originally posted by weganer View PostDear Oman,
maybe the test file for the VC1-codec in my last post, was not the best example because of too much action and fast cuts in the clip and the 29,970 fps.
So I cut out a scene from an original BluRay stream with VC1-Codec (23.976 fps) without action scenes, which is not playing smooth like all original VC1-Codec BluRay streams on the box.
Hope you can confirm it… or better have a solution.
If this clip is not stuttering on your box, the problem is on my side.
Here you find it (240MB): http://www.file-upload.net/download-.../test.rar.html
PW for the file is : omans82b
Thanks again for your help
weganer
Originally posted by mike808 View PostOman, can you please hard code change the permissions in the next release in boot.img so that we don't need a special version of xbmc that asks for root rights. I really want to use the SPMC version. Thanks.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View Post
Okey,fine..
Originally posted by Finless View PostBe careful giving special permissions to APPs or changing permissions in boot.img. You may open a security hole!
So, yes, please modify the permissions so that any version of xbmc can be installed without asking for root rights. Otherwise you need special version of xbmc to work with s802 amlogic box.
Originally posted by mike808 View PostNo, this won't open any security hole, these permissions are just to make xbmc work properly, for video and sound. Like Koying said in another post, xbmc shouldn't need root permissions to work properly, it's just a media center.
hmmm, BUT this way every APP get this permissions and that's what Bob talk about could be a security hole...RK3288 Devices
it's actually a amlogic firmware flaw, these permissions are not even needed with rockchip devices, it's just changing a few needed permissions from 664 to 666 so that xbmc can work properly. i haven't had my rk3066 or rk3188 hacked as of yet. i really don't think viruses etc., are a real concern for these android based tv players.
Anything specific your looking for in the next update or just want an update for update sakes?
Items in the works more releases here then on other boxes I really love the roms coming out for this device hats off to everyone😆Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostAnything specific your looking for in the next update or just want an update for update sakes?
as in message - http://www.freaktab.com/showthread.p...l=1#post214494
1.Navigation bar;
2.Power button function;
3.Power supply control for OTG port ;
4.Calendar/People sync;
5.Some air-mouse support;
6...........
Maybe new launcher..
and the usual bug fixes
Originally posted by gizmomelb View Postit's been a month since 108K4 dropped, with the amlogic source updates today I'm hoping we'll have a 109K4 drop soon. Oman, any estimated time for when we might see a firmware update please? thank you.
their changelog:
· Optimization Power Consumption
· Fix failed items for CTS.· Improve stability issue When auto reboot,auto suspend,Monkey test,AV file continue playing.
· Add protocol: UDP ,RTP , MMS ...
· Update NAND/EMMC driver.
· Fix some Wi-Fi throughput problem.
· Update PMUAML1218 driver.
· S802/S812 is compatible with same sof tware.
· Support Antut u videobench apk.
· Optimization display effect for HDMI.
· Support new feature DRM,Playready L1/L3,Widewine.
· Add Secure OS.
· Visit America websit netflix and youtube smoothly.
· Strengthen encoder stabilit y.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View Post· Fix failed items for CTS.· Improve stability issue When auto reboot,auto suspend,Monkey test,AV file continue playing.
I worked as a software QA tester for approx 5 years, so have fun with the regression and new feature testing, I'd be interested in how you automate testing on an android media box.. I'm guessing using commands sent over ADB?
There are currently 2299 users online. 1 members and 2298 guests.
