and don't worry about off topic....
Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Originally posted by WQGJ587 View Post
and don't worry about off topic....RK3288 Devices
- Overview BOX (LINK !)
Originally posted by Finless View PostDude, Oman works for Beelink so if they are now putting root in as stock, THEN IT IS STOCK!
Seems I may not have to do much for a custom ROM... But I see some things I can do
Do people still need 720P patch? Or are you using Oman's XBMC?
Any ideas how to solve this issue? (720p patch, another XBMC version,...)
Originally posted by kurthv View PostI have updated to 108k4 and tried different versions of XBMC (13.1, 13.2 beta, 14 alpha2), but I still have issues with my 720p TV. No matter what I try, I can only see the upper left section of the movie.
Any ideas how to solve this issue? (720p patch, another XBMC version,...)Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Any ideas how to solve this issue? (720p patch, another XBMC version,...)had the same prob on my second box
.... its just when u update ...... on clean new install no prob
Originally posted by Biatsch View Postdeinstall mx Player and xbmc ..... update xbmc https://www.dropbox.com/s/hax9ho6b9d...capp-stane.apk and it should workhad the same prob on my second box
Use stanes XBMC the MX Player?
What will happen, if I use MX Player Pro?RK3288 Devices
Does this mean, that all official XBMC releases won't work with 108k4 and 720p only TVs?
What's about the 720p patch/fix from Finless?
Is this also available for 108k4?
Originally posted by kurthv View PostOkay, I will try, when I am back home (next week).
2. dont Need the patch when u use stane xbmc
Hello Oman,
After fews day with your last ROM, i can say it's very stable, no reboot or freeze
2 problems, i ve noted:
1/ very strange problem with MX player, Moboplayer, ... i can't change voice track (for multi tracks sound movies). I can just play movie with first track. If choose second track, i hear 2 tracks in same time!
Of course, i check a lot of movies... mainly mkv multi movie.
FYI, i ve same behavior with Leolas v1.1 ROM.
2/ It seems screen saver feature is broken. My box fall in deep sleep after few minutes when i switch on screensaver.
Thx for your job, and your support
I am still confused why you need use the official xbmc,the stock xbmc is fine for 720P TVs..and xbmc from stane is also fine.
Originally posted by cee773 View PostIs anyone else box crashing to black screen on 108k4? I have the beelink m8b box was manufactured in may 2014.
The only thing I can confirm is the FW is ok, it might does matter to compatibility with TV or the PCBA is not solid on HDMI port..Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
There are currently 2946 users online. 0 members and 2946 guests.
