Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Originally posted by Yusi View PostHow about the 720p problem. Will there be a solution too?
Originally posted by Veronica View PostUsing external sdcard storage by default would be the best feature to have, instead of downloading third party apps like Directory Bind or Folder Mount (must purchase) to move important apps data like heavy games data to your external sdcard.
It's easy to get low on space on Internal storage as it is right now and internal storage wipe everytime we flash a ROM doesn't help at all.
I wonder if is really necessary to wipe internal storage when flashing firmware by sdcard, at list if you disable that it will be a lil' more easier and faster to set things up again.
Just my thoughts but crossing fingers for this to be in devs priorities to-do-list if possible
Originally posted by Veronica View PostAnother one to not foget is to force apps to open in landscape mode by default so no need again to use third party apps for that.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
the only "app" I know of that can control app orientation is an xposed module. It requiress the xposed framework to be installed. I believe the module is called app settings. It controls many aspects of apps as well including services/proccesses and much more. If you can get the dev of xposed to allow you to install his framework on your firmware there are many modules that would fix many peoples problems on here.@µ$ł!Ω
Originally posted by Nowandlayda View Postthe only "app" I know of that can control app orientation is an xposed module. It requiress the xposed framework to be installed. I believe the module is called app settings. It controls many aspects of apps as well including services/proccesses and much more. If you can get the dev of xposed to allow you to install his framework on your firmware there are many modules that would fix many peoples problems on here.
Another really good working solution is
so you don't need the xpose...RK3288 Devices
- Overview BOX (LINK !)
Like clean Master, FlowDroid, after i realized that i had to intall an app to force apps in lanscape mode so i don't know of other installed apps .
Pros:
Works
Cons:
I have to manually install and convert it to system app with TiBu or move it to /system/app and reboot
1 process, one service. Must run in baackground always
Icon stuck in notification bar
Re: Important - Stock Firmware - Beelink S82/M8 - Official FW Releases from Beelink - user feedback thread
Originally posted by freakkid View PostI use Adative Rotation Lock(Free).apk....just select Landscape and to Boot up on start up.....works for me
I believe the Paid version allows per application.....REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by abdul_pt View PostOman,
Why does your updates.zip wipe internal SD? Is there a reason that I'm not seeing ?
Tapatalked
--update_package=/sdcard/k200-ota-20140702.zip
--wipe_data
--wipe_cache
--wipe_media
FYI Abdul, my ROMs I do it in the ZIP edify script because I want to FORCE a fresh install.
I may start changing that and leave it up to the user now that we have a TWRP recovery
There are currently 3410 users online. 0 members and 3410 guests.
