Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Originally posted by Magnus33 View PostSync issue with media playback seems to be fixed also.
No option to use own pictures for screensaver iam heartbroken time for a drink
If you can push your pictures into system\media\screensaver\images ...
Ok,we'll try best to add this feature.
Originally posted by londonshore View PostYes oman can u please tell me what xbmc is on the 111k4 I like it so far and it gives me the option to minimize which I couldnt in the last rom great work
Originally posted by Ronin View PostHey Oman thanks for the new firmware and all the hard work really appreciated. I just have a question about the whole MAC address burning thing.. tried the mac address burning tool before and although it successfully changed the ethernet mac address the unit (mxiii 2g) can no longer switch between wifi and ethernet.. if I uncheck ethernet and check wifi the unit locks up and rebooting it does not help. Tried re-flashing with 109k4 and same issue. I tried reflashing using USB burning tool back to the original MAC that it came with and same issue so looks like reflashing MAC address kills wifi/ethernet switching. Would really appreciate your insight into this as it is driving me nuts.
3.Ethernet MAC (No need to modify Ethernet MAC by tool ,it can be produced by FW automatically and be unique)
Originally posted by vel2000 View PostFirst Bug:
When starting XBMC and the box is connected via the "AV Cable", the TV screen goes black (with the usual "No Signal") and I have to reboot the box to get a picture again.
Seems that XBMC kills the AV output somehow.
Guess, there is a setting messed up somewhere.
Which xml file contains XBMC's video settings?
Originally posted by bignelly79 View PostHi Guys
My mate got one of these boxes and I built it last night, it came with 108k4 but I upgraded to 109k4. The play back seemed good, tested a film versus my Minix and more or less played the same.
The issue I had was around IPTV, I had added in my IPTV list and then when I click on a channel there is a preview window on right hand side, the picture is off centre to the right so you can just see about 20% of the channel in the preview. Works ok when you open the channel fully.
Not a huge problem but wondering if there is a fix available?
Sorry if this has been asked already...I am trying to read over the 60 plus pages
Thanks all the dev guys!!
Originally posted by dlangejc View PostGot sum issues here trying to update. Currently on 108K4 which was flashed with the AML USB tool. Now trying pin hole method to upgrade to 111K4.
Can't seem to get into recovery and if it does the Android guy falls over.
Can see the files on the SD card and I have the correct 3 files. Tried formatting SD and used another SD card but the same result. Tried with a reboot recovery app but the same result.
Any ideas?
Is this the correct recovery? please see attachment 😄
[ATTACH]9392[/ATTACH]Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
The update app should work i tried it and things worked fine.
Recovery is certainly broken but its something that can be worked around tell a replacements done.
The screensaver is merely cosmetic since the stock doesn't repaat enough different pictures to avoid image ghosting on tv after a while (fortunately burn in near impossible on new tv)
Also yellow no my fav colorMk802IV Neomode 1.9a original rom 720p
Originally posted by londonshore View PostBob maybe see to fixing the bluetooth on ur update would be awesome if u can
And the detail of issue?
Thank you.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Yes,the bug exists
Originally posted by oman View PostAbout BT issue,could you give more hints? Your product is MXIII(2G) version,right?That means your wifi module is AP6330?
Thank you.
Say using Bluetooth headphones messes with the wireless throughput. (AP6330 is correct i believe)
Think this was even a issue with the rk3188 devices which used the old AP6210.
Driver or hardware flaw?Mk802IV Neomode 1.9a original rom 720p
Thank you.
1.what's kind of devices you used to pair the MXIII?
2. Take some pictures about thisEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
But iam guessing there both a drive issue with devices not connecting and a hardware design flaw that causes them to crap out when both wifi and bluetooth are used.
Seems unlikely to be a drive issue with a newer chipset causing the later.
All leave it to those using blutooth to post since i rarely do.Mk802IV Neomode 1.9a original rom 720p
There are currently 2425 users online. 0 members and 2425 guests.
