As far as Wireless Features go. I think they have the same CPU & GPUs though.
Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Originally posted by dlangejc View PostYup, will give it a go soon, what are your thoughts on the ROM Veronica? 😄
Just finishing setting up xbmc provided by Oman (i installed 11k4 by finless). Then i'll backup in twrp just in case
Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beel...
Originally posted by Veronica View PostSo far so good, no complains. i was on 108k4 but had random weird bootloops and i even had to unbrick burning the rom image using my computier.
Same here on the boot loops on 108k4 but back on stock 😉
XBMC 13.4 press again to minimize ... & audio sampling rate option
Hi people ... excellent forum here...
Oman thx for 111k and xbmc 13.4 ... i hv a question pls if u hv time
So the xbmc 13.4 is looking really good. first improvement i noticed is that livetv preview works with picture aligned to box without having to switch off amcodec. well done. Also I notice that now the return button will exit the movie as well.
1 thing im not sure about is the `press again to minimize` feature. this is not needed and its a bit of a pain ... so my question is how can i disable that pls ? can i edit the code ? if so where pls?
another thing i dont quite like is that now audio sampling rate is fixed and i cannot change the sampling rate. Although disabling this feature can prevent many people from using excessive sampling rates, this cld be a problem when trying to sync clocks between device & surround systems. pls note that audio sampling rate shld be set the same throughout the audio chain and when the clocks are not synced the sound servers can crash or be buggy in general.
can i edit the code somewhere to bring the sampling rate option back pls ?
for the rest ... we owe u a crate of beer dude
best of luck & health for 2015
gasdiver
Originally posted by dlangejc View PostUnable to setup manual DNS addresses on ethernet, when I click "Configure Ethernet Devices" click on static IP, I get the "Unfortunately, Settings has stopped" error.
Is there a work around for this?
I have the round beelink M8 box. I successfully updated it to 111k4 (from 109) using the zip file. I found a problem.
If the box goes to standby mode (red light) using the IR remote control, "sometimes" I cannot wake it up again neither using IR remote nor pressing the power button at the back. I have to long press the power to completely switch off and reboot it. This happens only "sometimes", but already very frustrating .... Anybody got similar problem ? hope this can be fixed soon.
Thanks.
Originally posted by oman View PostFW Release->
The latest:
Compatible with S82/S82B/S82H+Ap6210/Ap6330 and MXIII(1G&2G DDR)+AP6181/AP6210/AP6330--->All IN ONE
Upgrade by TF card: Download Here(111k4)
111k4->(Based on AML latest official SDK(1114))
1.Update xbmc (Based on SPMC13.4.0 --Thanks to koying);
2.Update Skype;
3.Ethernet MAC (No need to modify Ethernet MAC by tool ,it can be produced by FW automatically and be unique)
4.Compatible with our R89 IR Remote;
5.UPdate DLNA&Airplay;
6.Fix some issues on some streaming APP,such as Hulu,BBC ..
7.Many fixes on multimedia playing..
8.Other little tweaks.
PS:
1.Some MXIII(2G) version would be without BT option with this FW.
109k4->
1.Optimization Power Consumption.
2.Improve stability issue When auto reboot,auto suspend,Monkey test,AV file continue playing.
3.Add protocol: UDP ,RTP , MMS ...
4.Update NAND/EMMC driver.
5.Fix some Wi-Fi throughput problem.
6.Support Antutu videobench apk.
7.Optimization display effect for HDMI.
8.Support new feature DRM,Playready L1/L3,Widewine.
9.Add Secure OS.
10.Visit America websit netflix and youtube smoothly.
11.Strengthen encoder stability.
12.Change the Mxplayer to normal version;
13.Update xbmc to Gotham 13.2,and open some nodes' authority,so you can install any version of xbmc;
14.Make the physic power-key to be suspend/resume working by short press,and long press (5s) to shutdown;
15.Remove the Popup notification when xbmc/Mxplayer/... been ran at the first time;
16. Add an Icon to show/hide Status Bar;
17.Support Hausbell Mmini i8 and Rii Mini H7 air-mouse;
18. Make some portrait APPs to be showed to landscape,such as Antutu;
19.Fix issue:the A/V Async for MPEG2;
20. Fix issue:it may auto-wakeup when in suspend state;
21.Fix issue:the usb port may lose efficacy after resume;
22. Fix issue:no sound for Notification;
23. Improve some parts of MBXLanucher;
24.Fix issue:Google Calendar/People cant sync.
108K4->
1.Add 1080P24Hz support;
2.Support for NTFS/CIFS; --Offered by wasser
3.Change Input method to Latin,and remote can use;
4.Update Play Store;
5.Support for Mele F10 air-mouse; --Pulled from Bob's FW
6.Support for Xbox/PS3; --Offered by Bob
7.Change method of Root access; --Offered by leolas
8.Add kill-recent-task function; --Offered by daemonium
9.Update xbmc to Gotham 13.1,fix 4k playback and 2160P/720P HDMI display issue; --THX stane
10.Add remote function in Recovery Mode;--THX leolas
11.Adjust MBXLauncher,add Yahoo wether and Clean-Memory function,fix slow animation issue;
12.Fix issue->Power-key of Remote might lead to reboot;
13.Improve small probable of blurred screen.
107k4->
1.Add for CPBLTV live stream;
2.Decoding Dts/Dolby for S802;
3.Add suspend and Power-off function by Remote or power button from Status Bar;
4.Add root access permission.
106k4->
1.Enhance system stability;
2.It can flash Ethernet MAC;
3.Enhance the power of 4k video decoding;
4.Fix issue of 1080i video playing.
105k4->
1.Fix some LiveTV apk can't be ok;
2.Optimize Thermal control;
3.Optimize HDMI/AV;
4.Optimeze Launcher/Settings,use only 1080P UI;
5.Fix video burning test fail;
6.Support secure OS function;
7.Update NAND driver;
8.Support APK installation to external SD.
103k4->
1.Better xbmc for playing 4k video;
2.6210_8G compatible with 6330_16G,to be the same FW;
3.Add PPPoE;
4.Adjust thermal control,Special for Antutu;
5.Adjust HDMI signal to more TV compatible;
102k4->
1.Better xbmc,no async between audio and video ;
2.Fix 5G wifi compatibility;
3.Better for Antutu benchmark;
4.S802/S802B/S802H are all compatible;
5.Other little tweaking.
TOOLs:
Update tools by USB: USB_Burning_Tool_v2.0.4_x86 --> support win8
How to upgrade FW By TF card:
1.Unzip the zip/rar file,and copy 3 files(105k4.zip,recovery.img,factory_update_param. aml) to TF card Root directory;
2.Plug in the TF card and Power line,then pressing the button in the AV hole,then press power button,then release button in the AV hole.
3.OK,it will be into update process.
wasser V1.0.3 or how back to original FW plz help ty
Originally posted by lawin1 View Postdlangejc, have you solved this static IP issue? Can someone confirm this problem? Currently I'm on 109k4 and Ethernet connection with static IP, no problems so far. I'd like to upgrade to 111k4, but I need a static IP.
Unfortuantly I live in a Flat full of other 802.11 b/g/n Devices. Making it next to impossible to use here. Plus the fact that I get more bandwitdh though the 10/100TX Port. ~25MBs over 802.11n, as opposed to the ~48-ish MBs that I can pull though the 10/100TX Ethernet.
Note I only have the M82 (e.g. The 1G/8G Version), your S82 (2G/8G Version), may vary.
Hey guys the ones using oman 13.4 xbmc based on SPMC. Are you usig amlcodec? i still get drops and skips with AMLcodec but if i use libstagefrigh and mediacodec i get audio and video sync issues. I'm loading videos using nfs and my server box is right next to it, all ethernet wired. Before i had my 3tb hdd plugged in to the vega box with no problems but now i do.
what are your thoughts, setup using a media server / NAS?
Originally posted by Ichijoe View PostI think the Radio on the M82 (1G/8G), MXIII w/the AP-6181 is a bit sh--!
First of all it lacks both BlueTooth, and any 5Ghz Band(s), a or n.
As an upshot of this I think this Version can only get as high as 65Mbs MAX.
Hell even my Four Year old Tablet can get up to 75Mbs. In fact the fastest Device I have is a Netbook that does 130Mbs.
So getting back to the MXIII I find that I'm only able to use about the half of my Bandwidth ~ca. 25MBs as opposed to the 51MBs that I have at my disposal. So I get about 47~48MBs over the Ethernet Port.
Since those Numbers are concrete enough for me. I kinda gave WiFi up on this Device.
What's actually disappointing to me is the lack of GigE on these Devices.
I mean here we are entering 2015, and Base 10/100TX is still a thing!!
Originally posted by Oualid2013 View PostHi where i can find update in menu tronsmart s89 h
Check wipe data select zip from the sd card and click update (you of course need the three files from the download on the sd card).
Grab beer or drink of choice and wait tell it done 5-10 min.Mk802IV Neomode 1.9a original rom 720p
Originally posted by bignelly79 View PostThanks for advice, was wondering if 111k4 would help at all with the wifi?
On prior versions... Specifically 109k4. I was only scoring ~25MBs over WiFi on a 51MBs Connection, where as over the 10/100TX Ethernet Port it is more like a reasonable 47~49MBs.
Yes I am aware of such things as Overhead, and that its almost impossible to expect the full speed on ADSL.
No doubt theres probably some room to tweak it MTU up a bit, but, that's still One heck of a wack on the WiFi.
For this reason alone I've forsook it, laid down some CAT-5e ~15m worth of it, and never bothered to look back.
I don't know if the 65Mbps cap on the AP-6181 is whats to blame here.
But, I would have been at least expecting 130Mbps as the lowest speed and, more reasonably in +300Mbps range.
It seems that the AP-6181 is at least in this respect unable to deliver.
I think I shall probably give this MXIII to my Lil' Sis. and, get me the Minix NEO X8-H Plus.
Which I gather has all the "Bells & Whistles" that I'm looking for.
Specifically GigE, BlueTooth and, 802.11 a/ac/n @ in the little used 5Ghz space!
ty for help
There are currently 4503 users online. 1 members and 4502 guests.
