Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
HDMI output flicker on MX3 2GB
Great firmware! Thank you Oman!Last edited by EternalErection; 21 October 2014, 17:33.
Originally posted by indi123 View PostThanks for the reply. I'm using it for the MX3 beelink box. In the past s82 and MX3 firmware were compatible and it looks like 109k4 is compatible as well, just no bluetooth option. Is there a fix?
I noticed the user "justme" asking the same question the other day if people had issue with bluetooth.Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
Bluetooth
Hi Ant, I have tested bluetooth on the MXIII 2G /fw 1094k and I can confirm it does work. Tested with Bluetooth speakers.
Originally posted by ant View PostDon't think there's a fix at the moment. It must be a bug in the new sdk? Others have working bluetooth on older devices but the newer MXIII seems to have the issue....
Originally posted by Ronin View PostHi Ant, I have tested bluetooth on the MXIII 2G /fw 1094k and I can confirm it does work. Tested with Bluetooth speakers.Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Originally posted by irendulic View PostI'm pretty sure that on 108 I could have waken up the box from standby with my Tronsmart TSM-01 air mouse, but I can't on 109. Any way to enable this?Originally posted by woneal View PostAs an app developer for a digital signage company, I ran into something that was very interesting. I use webview in my app and with video the app always crashed. Now at first i didn't know but now i do. I had to add this permission in the app to get it to work.
<uses-permissionandroid:name="android.permission.WAKE_LOCK"/>
Whats odd is no other device had this issue without it but for some reason amlogic had to have it when running video with webview. This could be the cause to some apps crashing when video is played because their permissions dont include this permission. I dont know if its a bug but could fix a lot of apps.
Originally posted by Hoffes_tp View PostIs Oman active in the Forum?
So when to expect 110 Firmware?
which features we're getting?
Originally posted by Magnus33 View PostThe only major issue at the moment is a the video sync issue which seems to be related to resolution and bandwidth.
There also a few minor ones like trouble with ps3 controllers/Bluetooth.
The codecs are in major need of updating also.
Otherwise the firmware is very solid and stable.
Now if i could say the same for my neighbor.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by apos View PostHey all and gratz for the amazing work done here. I have flashed Oman's 109k4 fw to my MX III 2g box and it's quite impressive. The only glitch observed so far is that there is no bluetooth in settings, making bluetooth unusable. Same applies for finless 2.0. I tried Stane's latest fw and bluetooth is back and working. (tried both clean and dirty flash). Is this a known issue or just a problem at my end? Any input-solution is appreciated.
Cheers
If you reinstalled 108k4,does the bluetooth come back?Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
109k4
I Installed yesterday the firmware 109k4 and I can confirm that the Bluetooth works without problem in my case.
Thanks for this firmware !
P.S. I followed another method to update:
1.Insert the sd card and navigate to My Apps on the box
2.Select the App "Update"
3.Click on "Select" and navigate to the extracted zip file on your card
4.Click "Update"
5.The system will automatically boot in recovery and install the new firmware
Originally posted by oman View PostBob,how to change the thread title?
I wanna tell others that MXIII 1/2G version is also supported here.
I have not try a IMG install. it is the new version with out realtek wifi
Re: Important - Stock Firmware - Beelink S82/M8 - Official FW Releases from Beelink - user feedback thread
Originally posted by Noget6 View PostIf i try to installe the 109k4 firmware on my MXIII 4k 1G It just stops after about 8%.
There are currently 2536 users online. 1 members and 2535 guests.
