Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
    HDMI passthrough HDMI switch
    With the latest 109 update, HDMI is working much better. Since my A/V receiver only has 2 HDMI inputs, I have to use a Monoprice 4 port HDMI switch. Prior to this updated firmware, when using the switcher for my Vega S89H my screen was all flutery, and not useable. I had to use one of the receiver ports, now I can use the HDMI switcher. This solved a biggie for me.
    thanks
    Update:
    Started to watch a recorded football game from last night from live tv stream, mpeg 2 108i, every 5 to 10 minutes the sound would drop out for about 5 to 10 seconds, and sometimes the screen would go blank for a second or two. After watching for about half an hour, I switched back to the HDMI port on the A/V receiver and the problem went away.
    So, the 7. From Oman's list for Optimization display effect for HDMI still needs a little more tweaking.
    Also, I suffered from heat causing the video to become jerky, this problem seems to be solved. So, I won't need to drill hole in my box. The temp (using CpuTemp app) goes up to 80C and stays there for a few minutes then goes back to 75C, it used to almost immediately drop to 55C.
    So, jerky video from the heat dissipation problem seems to be solved. I won't need to drill holes in my box anymore.
    Also, watched the football game using the latest nightly Kodi 14 alpha 3, and it played flawlessly. Not a single dropped or skipped frame at all during the 3.5 hour game, that is just awesome. It was an mpeg 2 TS file and here is the media info for this file.
    General
    Complete name : \\RONS_NAS\DVBLink\RecordedTV\footbal-2020_20140921-71-12010000-1411345200.ts
    Format : MPEG-TS
    File size : 21.6 GiB
    Duration : 3h 28mn
    Overall bit rate mode : Variable
    Overall bit rate : 14.8 Mbps
    Network name : DVBLink Network
    Video
    Menu ID : 1201 (0x4B1)
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=15
    Codec ID : 2
    Duration : 3h 28mn
    Bit rate mode : Variable
    Bit rate : 13.6 Mbps
    Maximum bit rate : 90.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Active Format Description : Full frame 16:9 image
    Frame rate : 29.970 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.219
    Time code of first frame : 11:20:53;09
    Time code source : Group of pictures header
    Stream size : 19.9 GiB (92%)
    Audio #1
    Format : AC-3
    Format/Info : Audio Coding 3
    Mode extension : CM (complete main)
    Format settings, Endianness : Big
    Codec ID : 129
    Duration : 3h 28mn
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Delay relative to video : -92ms
    Stream size : 574 MiB (3%)
    Language : English
    Audio #2
    Format : AC-3
    Codec ID : 129
    Duration : 3h 28mn
    Bit rate : 96.0 Kbps
    Channel(s) : 1 channel
    Channel positions : Front: C
    Bit depth : 16 bits
    Delay relative to video : -102ms
    Stream size : 143 MiB (1%)
    Language : Spanish
    Text #1
    Format : EIA-708
    Muxing mode : A/53 / DTVCC Transport
    Muxing mode, more info : Muxed in Video #1
    Duration : 3h 28mn
    Stream size : 0.00 Byte (0%)
    Language : English
    Text #2
    Format : EIA-708
    Duration : 3h 28mn
    Menu
    Duration : 3h 28mn
    List : 49 (0x31) (MPEG Video) / 52 (0x34) (AC-3, English) / 53 (0x35) (AC-3, Spanish)
    Language : / English / Spanish
    Service type : reserved for future use
      DTS-HD & Dolby TrueHD support?
      Can someone test DTS-HD & Dolby TrueHD now?
        AW: Important - Stock Firmware - Beelink S82/M8 - Official FW Releases from Beelink - user feedback thread
        Why u dont test urself instead of asking ..... Just got an dts receiver
          Originally posted by scooter2014 View Post
          Ok will do Oman, ps never heard back from your rma guy re the 2 boxes i have with bad hdmi they now only connect at 720 p and id like to get both replaced.
          I soldered my hdmi ports on my 2 boxes.... Had the similar problem ... U ju just have to heat up the hdmi pins on the board with an electrical soldering iron to connect the pins new
            DTS-HD passthrough not working (only DTS core), Dolby TrueHD - I don't have properly files to test. (MXIII and Denon AVR-1610).
              Working edonon spanish cable tv app (nagravision encodded) first time with 109k4 (didn't work on 103k4 & 108k4).
              Very pleased endeed.
              Enviado desde mi Nexus 4 mediante Tapatalk
                Originally posted by JustMe View Post
                read my last post new firmware has improved bitrate and resolution but just short of hd
                http://www.freaktab.com/showthread.php?14583-Netflix-HD-Playback&p=230408#post230408
                JustMe
                I've spent hours reviewing the whole thread,known what you are talking about..
                Your AVR must support DTS-HD /True-HD first..
                Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
                  My Denon AVR-1610 support DTS-HD and DD True-HD. I have many BluRay discs and files with DTS-HD and all of this working well in BluRay player or PopcornHour A210.
                  In MXIII i have only DTS core. Not DTS-HD.
                    Oman im having an issue .. the standard remote wont work after update
                    Sent from my GT-I9505 using Tapatalk
                      Re: Important - Stock Firmware - Beelink S82/M8 - Official FW Releases from Beelink - user feedback thread
                      Originally posted by oman View Post
                      FW Release->
                      The latest:
                      Upgrade By USB: Download Here(108k4)
                      Upgrade By TF card:Download Here(108k4)
                      Upgrade by TF card:Download Here(109k4)
                      109k4->
                      1.Optimization Power Consumption.
                      2.Improve stability issue When auto reboot,auto suspend,Monkey test,AV file continue playing.
                      3.Add protocol: UDP ,RTP , MMS ...
                      4.Update NAND/EMMC driver.
                      5.Fix some Wi-Fi throughput problem.
                      6.Support Antutu videobench apk.
                      7.Optimization display effect for HDMI.
                      8.Support new feature DRM,Playready L1/L3,Widewine.
                      9.Add Secure OS.
                      10.Visit America websit netflix and youtube smoothly.
                      11.Strengthen encoder stability.
                      12.Change the Mxplayer to normal version;
                      13.Update xbmc to Gotham 13.2,and open some nodes' authority,so you can install any version of xbmc;
                      14.Make the physic power-key to be suspend/resume working by short press,and long press (5s) to shutdown;
                      15.Remove the Popup notification when xbmc/Mxplayer/... been ran at the first time;
                      16. Add an Icon to show/hide Status Bar;
                      17.Support Hausbell Mmini i8 and Rii Mini H7 air-mouse;
                      18. Make some portrait APPs to be showed to landscape,such as Antutu;
                      19.Fix issue:the A/V Async for MPEG2;
                      20. Fix issue:it may auto-wakeup when in suspend state;
                      21.Fix issue:the usb port may lose efficacy after resume;
                      22. Fix issue:no sound for Notification;
                      23. Improve some parts of MBXLanucher;
                      24.Fix issue:Google Calendar/People cant sync.
                      108K4->
                      1.Add 1080P24Hz support;
                      2.Support for NTFS/CIFS; --Offered by wasser
                      3.Change Input method to Latin,and remote can use;
                      4.Update Play Store;
                      5.Support for Mele F10 air-mouse; --Pulled from Bob's FW
                      6.Support for Xbox/PS3; --Offered by Bob
                      7.Change method of Root access; --Offered by leolas
                      8.Add kill-recent-task function; --Offered by daemonium
                      9.Update xbmc to Gotham 13.1,fix 4k playback and 2160P/720P HDMI display issue; --THX stane
                      10.Add remote function in Recovery Mode;--THX leolas
                      11.Adjust MBXLauncher,add Yahoo wether and Clean-Memory function,fix slow animation issue;
                      12.Fix issue->Power-key of Remote might lead to reboot;
                      13.Improve small probable of blurred screen.
                      107k4->
                      1.Add for CPBLTV live stream;
                      2.Decoding Dts/Dolby for S802;
                      3.Add suspend and Power-off function by Remote or power button from Status Bar;
                      4.Add root access permission.
                      106k4->
                      1.Enhance system stability;
                      2.It can flash Ethernet MAC;
                      3.Enhance the power of 4k video decoding;
                      4.Fix issue of 1080i video playing.
                      105k4->
                      1.Fix some LiveTV apk can't be ok;
                      2.Optimize Thermal control;
                      3.Optimize HDMI/AV;
                      4.Optimeze Launcher/Settings,use only 1080P UI;
                      5.Fix video burning test fail;
                      6.Support secure OS function;
                      7.Update NAND driver;
                      8.Support APK installation to external SD.
                      103k4->
                      1.Better xbmc for playing 4k video;
                      2.6210_8G compatible with 6330_16G,to be the same FW;
                      3.Add PPPoE;
                      4.Adjust thermal control,Special for Antutu;
                      5.Adjust HDMI signal to more TV compatible;
                      102k4->
                      1.Better xbmc,no async between audio and video ;
                      2.Fix 5G wifi compatibility;
                      3.Better for Antutu benchmark;
                      4.S802/S802B/S802H are all compatible;
                      5.Other little tweaking.
                      TOOLs:
                      Update tools by USB:
                      USB_Burning_Tool_v2.0.1_x86
                      How to upgrade FW By TF card:
                      1.Unzip the zip/rar file,and copy 3 files(105k4.zip,recovery.img,factory_update_param. aml) to TF card Root directory;
                      2.Plug in the TF card and Power line,then pressing the button in the AV hole,then press power button,then release button in the AV hole.
                      3.OK,it will be into update process.
                      Any ideas about how to make the remote work ?
                        @Bob - will you release your Firmware based on 109?
                          Beleive he already working on it.
                          Mk802IV Neomode 1.9a original rom 720p
                            heat up from the rear of the hdmi? or on bottom of the board i have two boxes like this and getting worse not better. looks like alot of pins top side of board and tricky to get a soder in there?
                              You can find some good info in on the hdmi issues in this thread: http://www.freaktab.com/showthread.p...tput-from-HDMI
                              Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
                              Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
                                I fixed 4 of the S89-H boxes like on post #28.
                                southpole
