Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Just installed 107k4 on my S89H and let it restore my back up from Finless 108 rom. One thing that I noticed, was that while playing my live TV stream in mp4 format using the latest Helix XBMC nightly, the audio plays with Dolby Digital but get no video. Using an app for the live TV stream, it plays fine. Not sure why there is no picture inside XBMC. Playing my mkv files from my NAS works great. I really can't understand why this rom would have an effect on XBMC, when all the other roms that I have tried have worked great. The software power off works also. Netflix still has the same problems for me, but did not expect any changes there. I have not tested it long enough to see how the CPU temp is handled, but all the other roms have the same problem of video going into slow motion when the CPU temp reaches 80C.
I am very pleased with this box, but there is still room for improvement.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Ps3 bluetooth controller support
Hi Oman,
First I would like to thank you & your team at beelink for bringing all the new updates fast we are very greatfull for all your hard work. I have a beelink m8 its running almost perfect
Is there anything you & your team can do to get the Bluetooth ps3 controller work as far as I no no one has got it working on any amlogic device ( A challenge for you). it worked perfect on rockchip 3066 & 3188 devices, can you help make this device completePlease consider making a Donation to freakTab
I have try the firmware S82B_107k4_sdcard on my M8 (k200, MBX), I was in
Android 4.4.2
Build Number : KOT49H.20140616 Test-keys
Kernel version : 3.10.33
Model : k200
After having install the S82B_107k4_sdcard, I wasn't able to manage the device with my small remote control.
I have plug an usb keyboard, install EZ Explorer, and then I have replace the file /etc/system/remote.conf by the one I had in k200-ota-20140616.zip
after a reboot I have my small remote control working again.
XMBC 14 is look like working and MX player alse, without the need to add a script to do a
chmod 666 /dev/am*
The problem I have is I don't have audio.
Can someone help me to manage this problem, or to explain me how to rollback to an older firmware by using an SD Card, please.
I have try to downgrade to my old firmware, but the recovery mod was telling that a more recent version is currently installed.
I'd like to solve the sound issue.
Thank for your help.
Regards
Actually already done by bob for amlogic so coming soonMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostActually already done by bob for amlogic so coming soonPlease consider making a Donation to freakTab
Originally posted by Biatsch View PostYep ....its just disturbs me when using xbmc
Originally posted by Yusi View PostAny chance you add a solution for 720p-TVs without this patch from finless? There must be an easier/better way..
Originally posted by clarkss12 View PostJust installed 107k4 on my S89H and let it restore my back up from Finless 108 rom. One thing that I noticed, was that while playing my live TV stream in mp4 format using the latest Helix XBMC nightly, the audio plays with Dolby Digital but get no video. Using an app for the live TV stream, it plays fine. Not sure why there is no picture inside XBMC. Playing my mkv files from my NAS works great. I really can't understand why this rom would have an effect on XBMC, when all the other roms that I have tried have worked great. The software power off works also. Netflix still has the same problems for me, but did not expect any changes there. I have not tested it long enough to see how the CPU temp is handled, but all the other roms have the same problem of video going into slow motion when the CPU temp reaches 80C.
Originally posted by Servant7 View PostHi everyone.
I don't know if I have the S82 or the S82B.
Is this firmware compatible with both or only with the S82B. Thank U.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
AW: NEW - Firmware - Issues feedback here for S82/Beelink M8|||Official FW Release |||Solution
Originally posted by daniello9 View PostNow I know what you mean .. my measy device shows the same behaviour and it really is annoying. But on the measy I can manually turn off the pointer .. and if I recall correctly you said there is an off function for the pointer on the Rii device too.
Originally posted by blinkone View PostI hope you are right & you have some inside information. I no Bob & woomg was working on it but as far as im aware it did not work for the bluetooth ps3 controller, no one can get it working so this fix would be great..
read release notesMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 2531 users online. 0 members and 2531 guests.
