Downgrading from 105k4 to 104k4 hangs me on Tronsmart Logo Screen !!!
Originally posted by versus4582 View PostSo we can safely conclude that there was indeed a hardware change, which for an unknown yet reason does not allow 104k4 to be flashed !!!
Hmmm ...
Ok, to save ourselves some time, can just someone enlighten us why 104k4 had the best frame rates, and apply that same logic to 106k4 and be done with it ??? Then we would not want 104k4 even though 106k4 still can't show picture from 13.1 XBMC official !!!!!
As far as I've Learned from Bob's posts ;Different Nand Chips are enough for the Fw incompatibility
Ditch the 104k4 but apply its strong parts to106k4 and we are just fine :
a) Best Frame Rates on FullHD 60+FPS consistently
b) It could play properly content on 13.1 Offiicial XBMC
Once these 2 are ported to 106k4 issue solved !!!!
Originally posted by versus4582 View PostFair enough .. So lets apply my previous suggestion !!!
P.s Dont trust system info %100, I know its good to show 60fps on promotion videos but it is not perfectly accurate all the time, like 30C fix temp. info or 1080p resolution info on 720p TV
Originally posted by TMx View PostDon't worry ,Give them some time Oman will not let you down ,He is probably working on it right now and release what you are looking for soon...
Its not promotioon videos !! Its my videos
Hmmm ...
Is this new mboard (with hw change) better regarding overheating problem?
OK now that I know NAND memory has changed I bet I can get 104K4 to boot on new boxes.
We need is the ntfl KO module from 105 and put it in 104K4 boot.img
As they make changes they will make new ntfl KO modules that will be downward compatible but old ROM wont be upward compatible!
Let me make a quick boot updater zip and see if it works.
Try this boot for 104K4 FInless 1.6 on new boxes
OK I think this maybe the reason. Keep your fingers crossed.
This is a updated Finless 1.6 (104K4) boot.img installer.
I used the new ntfl KO module from 105K4 and put it in my boot.img for my 1.6 ROM.
It might also work on stock 104K4 but I did not try it.
Instructions:
1) Flash my 1.6 ROM from recovery ONLY! If you do not do it from recovery the box will reboot and you will be stuck.
2) Now after flashing my 1.6 ROM do not reboot in recovery but go ahead and again install from EXT and install this zip over top.
Here is the modified boot.img
https://drive.google.com/file/d/0B9B...it?usp=sharing
Let me know if this make my 1.6 ROM boot on the new boxes with new NAND chips.
Originally posted by Finless View PostOK I think this maybe the reason. Keep your fingers crossed.
Instructions:
There are currently 4002 users online. 0 members and 4002 guests.
