MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
Originally posted by spamer View PostThis one should work: http://www.dx.com/p/usb-2-0-10-100mb...1#.VLV6C3tc_6o
Looking for stable Android 4.4.2 ROM for my MK908 TV stick
I am looking for stable Android 4.4.2 ROM for my MK908 TV stick.
It looks like this ROM is more stable than others.
Can I use this ROM on my MK908 with few changes.
If so, could any one point me to instruction to do that.
If not, please suggest me the right ROM for my MK908.
Thanks,
Raju
Question about 1080p
I have MK809III, i can put in 1080p 60 HZ and my LCD recognizes as 1080p but CPU-Z say that the screen resolution is 720p (Antutu also), the same thing happen when see youtube videos the max resolution setting is 720p. I thought put a new rom and found this SMIC717394 1080p ROM, but I saw videos of this ROM and when run CPU-Z also say that resolution es 720p.
My question is, if this rom really work at 1080p then CPU-Z show a wrong screen size and so it is possible that my rom really work at 1080p too and don´t need change it.
For the people using this ROM, how do you know that really work at 1080p?
Originally posted by speedy32 View PostI have MK809III, i can put in 1080p 60 HZ and my LCD recognizes as 1080p but CPU-Z say that the screen resolution is 720p (Antutu also), the same thing happen when see youtube videos the max resolution setting is 720p. I thought put a new rom and found this SMIC717394 1080p ROM, but I saw videos of this ROM and when run CPU-Z also say that resolution es 720p.
In the Android screen setup there is an item for the HDMI setup and you can chose the resolution and frecuency for it. I have an MK802IV with the same board and these apps says the same but the resolution is 1080 veryfied on my TV (the info button says the input signal resolution).
Kind regards.
hello guys! Here is my problem:
I bought an MK809 IV RK3188T 1.4 Ghz quad core 2 GB ram. When i receive from aliexpress i have 4.2.2 and i wanted to upgrade to 4.4.2. But after rom flash i got an boot loop , i see again and again the 4 penguins on boot, and now doesnt want to boot any more. What should i do? help me please.
Registered just to say thank you. The stock rom kept randomly disconnecting Bluetooth for me, and then would refuse to connect any new devices. I got fed up of restoring to factory settings, so I looked for another rom, and found this one. I've been using it now for a month and a half, and have yet to find a single issue.
Thank you, thank you, thank you.
Edimax wifi
Hi... I`ve started using my Mmk802IV again, had to moved it so I can`t use my powerlines any more.
I want to you use my Edimax nano wifi module ( because the wifi on it is crap ) Can anyone point me in the direction of what to do? I`m pretty handy with the OS.. but I don`t know what I need and where to put drivers etc..
thanks
There are currently 2819 users online. 0 members and 2819 guests.
