MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
Originally posted by mechaone View Post*
SMIC: Thank you again for a fantastic rom! Im still running V2, but want to go to V4 this weekend.
Everything is performing like a dream with only a few exceptions. I still havent identified whether Im the only cat affected by the 1.8ghz full range kernel responding with 1.6ghz speed cap upon boot. Ive also run into odd issues with some music players. The Soundcloud app plays only a second of any given track and then advances to next song, but it must be an app or server issue regarding the device , as even my phone and Nex7 tablet exhibit similiar behaviour. The principle difference being that all my other devices play near full tracks before switching songs automatically. My guess is that the Soundcloud servers dont recognize my device identifier and prompt a track bump for some reason. Even then, I'm not sure why.
Winamp has never loaded on screen with my stick, but I was hoping the fw switch would alleviate the issue. It hasn't. The app supposedly runs but refuses to do anything but give home screen when I try to use it. Have yet to ever see it's interface on my mk802iv. The "Music" app is odd as well, as it shuts down to home screen when I attempt to play a song through internal, ext sd or usb drive.
Im not looking for answers so much as to identify if im the only one with these questions. I'm of the belief that I may have transported an issue from previous fw installs when restoring data and settings in this rom.
Anyone here seeing these issues as well?
Sent from my SGH-I337M using Tapatalk
I also have the same "Soundcloud" problem. Add to that some video apps like "Viral" won't play video. I'm using QS2 rom on Imito QX1.
cheers
Re: MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
Originally posted by nghalion View PostI also have the same "Soundcloud" problem. Add to that some video apps like "Viral" won't play video. I'm using QS2 rom on Imito QX1.
cheers
Originally posted by pelias View Posthello, how did know wifi version on my 809III?
best regards
Sent from my SGH-I337M using TapatalkPlease post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
help
Originally posted by smic717394 View PostHi guys,
This is my first ROM for the MK809III. I dont even have the MK809III to test it so I had to rely on you. Few members already test it with success.
This ROM is for the 809III with AP6210 wifi and bluetooth boards V2 and V3.
You have 1080p and extra kernels 1.6, 1.7 and 1.8 in stock DDR or overclocked to 667.
The 1080p ROM
- Kitkat 4.2
- HD resolution (1920x1080) - 1080p
- 1.8V LCD support (to prevent flickering HDMI on some units especially the RK3188T)
- Proper root
- System debload
- Installed the following apps: AnTuTu Benchmark, Beyond XMBC, MX Player and Codec, Reboot, Text Droider dpi and YouTube
- VsyncFix - to fix the skipping frames on video playback
- DTS and 5.1 AC3 pass-through support
- Busybox and supersu updated
- Tcp tweaks added
- No-Frill cpu control
smic717394_809III_1080p_V4.4.2_ROM_V3
----- New versión ROM: V4----
On the rom side, I fixed few bugs with the daemon and update the supersu and binary to latest version 2.01, install twrp recovery, added few more apps, remove the beyondxbmc as in kitkat the HW acceleration doesn’t work yet, change the default wallpaper to a simple brushed aluminium look, modified the Launher3.
Beside the standard apps, the new apps installed in this rom are:
- Antutu – Benchmark app.
- Autorun – This app allow you to automatically start one or more apps when the unit starts.
- No-frills CPU control – Allow you to change the CPU max and minimum, and governors.
- Reboot by petrus – Updated to v 1.2.2
- SPMC 13.2 – XBMC for RK3188
- Terminal Emulator
- textdroider_dpi – allow you to change the dpi to a smaller or larger one.
- install TWRP recovery.
On the kernel side, I implemented the video shutter fix, modify the rockchip hdmi drivers so if it doesn’t mute when the HDMI is disconnected or in case the SOC detects your connection as DVI.
The kernels are now compressed, mainly to prevent patching not by you fine people but by company that uses the ROM made by the great devs from Freaktab. We put allot of work and hours into this ROMs and few companies think that if they download than patch the kernel with their brand its theirs, not fairs. So here are my terms for using this rom. As a private user and as a member of this page you can use the rom as you like, without any limitation what so ever, but I would appreciate if you leave my boot animation, it’s all I have to show after all. If you want to use the ROM commercially, you cannot remove any of the branding from the ROM and from the Kernel, you can use it as you wish but as it is, if you want to change it you can get in touch with any dev from this side only.
Now all that been said let’s get back to the kernel. I created 10 versions. The kernels marked h have only high frequency’s.
For example a kernel kernel_1.6_667 will have cpu 312, 504, 816, 1008, 1416 and 1608 and the GPU 664 and DDR 200, 266, 300, 400, 600, because the CPU can drop all the way to 312 when not used allow the unit to run cooler and more stable. The kernel kernel_1.6_667 will have cpu 1200, 1416 and 1608 and the GPU 664 and DDR 200, 266, 300, 400, 600, because the CPU will only drop as 1.2 as min speed the box will run hotter but you get more points on benchmark (not real performance).
As usual, I hope you guys like it, and since next week I´m off in holiday, I may not be able to reply as fast but I hope you enjoy the ROM.
Note:
You have to rename the parameter before opening the RKAndroidTool. Also please note that you can only flash the parameters when you flash the rom and not after so if you want to change the size you will have to flash again so back up your data.
Also When you flash the ROM do a EraseIDB before (dont do it if you just flashing the kernel)
After flashing with a different system partition (parameter) size than your previous ROM - you need to go to System -> Storage and mount SD card. You will get a notification saying something about "Damaged Memory". Open this notification, and format the SD card.
frst error is device can not flash mode because is not a msc device that is happen when i wont to start up a reebot to flash everething alse is working
another ne error failed to mount meta data
Originally posted by loopi View PostI have problem with start up when i plug in my tv i get a error code and newer wont start up the error is
another ne error failed to mount meta dataFor all your computer problems...
http://www.salvamipc.es
Hi, ill start working on a mediatek first then rtlFor all your computer problems...
There are currently 1511 users online. 2 members and 1509 guests.
