MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
Originally posted by walternet View PostFor all your computer problems...
http://www.salvamipc.es
Originally posted by SASSYBOY View Posthave wifi (RTL8188) kernel for 1080p?For all your computer problems...
Originally posted by Dzigi.Bau View Post@smic717394
Just wonder.
There is a small lag in video playback, which is probably caused by drivers not correctly calibrated how to handle memory, you know after memory is filled, it makes a lag during emptying.
Could you make a kernel based on kernel_24Hz_i.img but with 1704 CPU and slightly overclocked DDR. I just would like to experiment something. Thank you.For all your computer problems...
Hi, good job!
I'd like to ask you something. I don't like SuperSU always ask me about "grant full access... bla bla bla" and later shows that toast. Also I'd like to hide the SuperSU icon. I know I can do it from the app settings but... is it possible to set these three things and later get the APP? I want (need) install the APP in my firmware like that because in some of my APK I send some intructions (with "su") by adb and I can not show all this, user needs to get the result as simple as possible.
Thanks!Android TV Box direct from China. English & Español
MK802IV fantastic ROM!
hi:
I have a new stick with WIFI MK802IV was with NeoMode 1.9.El Wifi was pretty bad and could not get the video playback was smooth.
I installed this ROM SMIC717394 ---- 1080p with default parameters and is a past, has improved the wireless system very fluid video playback without jerks and especially quality streaming video.
Thank you very much for this rom, you've given us a scarlet joy and forgive my English.
By favo, continues to update and improve it because now borders on perfection, but if you have more news above, it will be perfect.
Re: MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
Originally posted by jolund View Postcan you add netflix app, please?
Most roms only have a few 3rd party pre-installed apps necessary for system function or maintenance. As a commonly available media app, Netflix must be installed after rom flash.
Sent from my SGH-I337M using TapatalkPlease post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
Originally posted by mechaone View PostThe Netflix app can be found at the Play Store.
I've seen that some roms have this netflix app preinstalled.
I get overheat problems, the sticks (all I tested) becomes hot when play 1080p youtube videos, also when play 3D games, after 2-3 minutes the sticks reboot because they are too hot.Android TV Box direct from China. English & Español
Also XBMC Beyond makes the sticks hot, I can play 1080p videos by MX Player (in my oppinion the best player) but XBMC make the stick so hot that reboots (even can not boot 3 or 4 times until becaomes cold).Android TV Box direct from China. English & Español
There are currently 2052 users online. 0 members and 2052 guests.
