MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
Because this MK809III was able to clock to 1.6 GHz with the SAM 1080p Kernel - CPU @ 1.8GHz, RAM @ 1.2GHz kernel and the Neo V1.7 JellyBean ROM and Antutu scored 18310.
I took some time and played with loading the kernels included in V2 on smic's V1 ROM.
No luck getting past 1.4 GHz with the KitKat kernels but here is what I found in case anyone is interested:
- kernel_1.6_full_range (CPU 312 -1600MHz - GPU 133 - 600MHz - DDR 200/667)
After many Boot loops it finally loaded but reboots again soon after- CPU 312 MHz -1.4 GHz
- kernel_1.6h_600_667 (CPU 1200 -1600MHz - GPU 133 - 600MHz - DDR 200/667)
Stable - CPU 1.2 GHz - 1.4 GHz AnTuTu 17266
- kernel_1.6h_stock_stock (CPU 1200 -1600MHz - GPU 133 - 600MHz - DDR 200/400)
Stable - CPU 1.2 GHz - 1.4 GHz AnTuTu 16640
- kernel_1.7_full_range (CPU 312 -1700MHz - GPU 133 - 600MHz - DDR 200/667)
After many Boot loops it finally loaded but reboots again soon after- CPU 312 MHz - 1.4 GHz
- kernel_1.7h_600_667 (CPU 1200 -1700MHz - GPU 133 - 600MHz - DDR 200/667)
Stable- CPU 1.2 GHz - 1.4 GHz AnTuTu 15696
- kernel_1.7h_stock_stock (CPU 1200 -1600MHz - GPU 133 - 600MHz - DDR 200/400)
stable- CPU 1.2 GHz - 1.4 GHz AnTuTu 15711
- kernel_1.8_full_range (CPU 312 -1800MHz - GPU 133 - 600MHz - DDR 200/667)
stable- CPU 312 MHz - 1.4 GHz AnTuTu 16757
- kernel_1.8h_600_667 (CPU 1200 -1700MHz - GPU 133 - 600MHz - DDR 200/667)
stable- CPU 1.2 GHz - 1.4 GHz AnTuTu 16469
- kernel_1.8h_stock_stock (CPU 1200 -1600MHz - GPU 133 - 600MHz - DDR 200/400)
stable- CPU 1.2 GHz - 1.4 GHz AnTuTu 16060HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
Re: MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
Originally posted by imaddiced2u View PostBecause this MK809III was able to clock to 1.6 GHz with the SAM 1080p Kernel - CPU @ 1.8GHz, RAM @ 1.2GHz kernel and the Neo V1.7 JellyBean ROM and Antutu scored 18310.
You get about 17000 on a 1.4 not too bad.For all your computer problems...
http://www.salvamipc.es
Originally posted by smic717394 View PostStrange that eill only work stable on high cpu. There is a wsy to unlock the T , but ic rockchip locked it its probably for a reason. I can look into it and try to compile a kernel for you.
The SAM kernel I was using in the past must have had the T unlock built into it, might be nice to give your ROM a try at 1.6 GHz but no point if it might kill the CPU.
It was the kernel_1.6_full_range and kernel_1.7_full_range that wouldn't run but kernel_1.8_full_range and all the others run fine. Could it be something wrong in those two files? Doesn't really matter the kernel_1.8_full_range kernel runs fine for me.HK1 Pro Plus
FlowFon F1
MXQ Pro+
R-TVBOX Mini+
MK809III
I recieved my tv box yesterday. I opened it but could not find/read which wifi/bt set it has. The board mention cyx_809III v5.0 20140510. Does any body know which chipset it has and if this rom can be used.
Verstuurd van mijn GT-N8013 met TapatalkLast edited by gdroos; 04 July 2014, 09:02.
Originally posted by gdroos View PostI recieved my tv box yesterday. I opened it but could not find/read which wifi/bt set it has. The board mention cyx_809kIII v5.0 20140510. Does any body know which chipset it has and if this rom can be used.
Verstuurd van mijn GT-N8013 met TapatalkHK1 Pro Plus
FlowFon F1
MXQ Pro+
R-TVBOX Mini+
MK809III
Verstuurd van mijn GT-N8013 met TapatalkFor all your computer problems...
Originally posted by smic717394 View PostAre you sure is cyx_809kIII v5.0 and not cyx_809III v5.0? the V3 used mediatek chip, the v5 i cant find anything. There is a easy way install HW_Monitor Hardware Detection from PlayStore and identify the chip.
Verstuurd van mijn P6-U06 met Tapatalk
Originally posted by gdroos View PostJust updated to 809iii and added picture. thanks for your effort
Verstuurd van mijn P6-U06 met TapatalkFor all your computer problems...
HK1 Pro Plus
FlowFon F1
MXQ Pro+
R-TVBOX Mini+
MK809III
Hello,
your ROM works really good on my MK809III.
Is it possible for you to add the following Kernel Patch in one of your next Releases: http://solutions.3m.com/wps/portal/3...pport/Support/ (Of Course you must Choose Android as Operating System :-) )
It would make the Stick work with Iiyama Prolite t2735msc Touchscreen-Monitor.
tiga05
Originally posted by gdroos View PostI recieved my tv box yesterday. I opened it but could not find/read which wifi/bt set it has. The board mention cyx_809III v5.0 20140510. Does any body know which chipset it has and if this rom can be used.
Smic: I still haven't flashed my stick. Too much going on in life right now. Will run it tonight and post asap.
Sent from my SGH-I337M using TapatalkPlease post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
I put V2 on my second MK809III with a T CPU today. I used the 1.8 GHz full range kernel. It show a clock range of 312 MHz to 1.416 GHz. AnTuTu result was 15334 while my other MK809III with T CPU is still running V1 and gives an AnTuTu result of about 17000.
I wonder why there is such a difference?
EDIT:
I put the V2 ROM on the other MK809III and it still gets 17000 on AnTuTu.Last edited by imaddiced2u; 05 July 2014, 00:15.HK1 Pro Plus
FlowFon F1
MXQ Pro+
R-TVBOX Mini+
MK809III
After several days of running this ROM I can provide more great feedback. This is the best ROM I've run on this particular stick, by far. It's very stable, with only the occasional bug after every few hours of use. The only rom that has given me similar satisfaction is Quickshot 3.1 and that only ran on my RK3188T sticks.
Netflix is smooth via wifi, with a very high resolution. You may know that Netflix quality varies by device. It looks substantially better than Netflix on my Imito QX1.
I've used a USB sound card for headphone use, and it worked great.
Bluetooth seems fine, I used it with my Moga Hero Power for gaming, and quality dropped off after 10 feet. I haven't yet tried my Bluetooth headset for audio, but I will.
I can't stream 1080p video from my network via wifi, but that is understandable due to the internal antenna. My Imito QX1 is streaming Blu-ray fine from my NAS.
The only minor bugs are that rarely, an app will crash without loading. Repeatedly. I've tried clearing RAM and closing apps manually but still the app won't load. It could be any app. Rebooting the stick solves the problem.
I've also had several system crashes transferring files upwards of 1 gig across my network. The system will just reboot.
Neither of these bugs is serious and I have seen them with other ROMs. I still heavily recommend trying this ROM if you have an MK809III.
There are currently 877 users online. 0 members and 877 guests.
