MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
Originally posted by imaddiced2u View PostFor all your computer problems...
http://www.salvamipc.es
Originally posted by PolloLoco View PostIf you have an MK809III with new wifi (ap6210) and an RK3188T, try the Quickshot 3.1 rom instead for the Mk902. I installed it on 4 RK3188T sticks I gave away, and it over clocked them. Only problem was that the sticks got very hot, so I ended up using another kernel. But try the stock install first and see if it works.
Another thing you could try, I never did this, is install a kernel that overclocks the RK3188T over smic's rom. I installed this over Quickshot:
http://www.freaktab.com/showthread.p...All-(well-most!)
For my TRUE RK3188 sticks, I use this ROM - normal install. Actually, smic717394 created a custom kernel to give us sound on older tv's. I am not sure if that was added to his link yet.
Both custom roms are great, I would be happy to use either one.HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by PolloLoco View PostOdd, are you sure you tried Quickshot 3.1?
Edited due to simultaneously posting.For all your computer problems...
Originally posted by smic717394 View PostHi PolloLoco,
I can add EXFAT, I didn't see the need for it because of its limitations, regarding the launcher reset itself after reboot, I´m using the same ROM and its not happening to me.
As for the dock, you've added apps to the home screen directly to the right of the "app button"? Any app I put there gets erased when I reset. I've tried several.
I think "play" mentions it also on the first page of this thread, when he talks about loss of some app on homescreen.
Originally posted by ViperRunner View PostHi,
Just to report that the wifi and bluetooth on my Mk809iii with MT59315A & MT6622 doesnt work
Thanks for all the work and all the efforts!
Best regards
Try this kernel
I tried your firmware from first post.
Tested built-in kernel and this one too:
On both WiFI and bluetooth do not work.
Please check this firmware by neomode:
http://www.freaktab.com/showthread.p...Fi-Version-0-9 (WiFi and bluetooth work there).
Can you please fix your kernel for MTK?
Regards,
Benobi
Regards,
BenobiFor all your computer problems...
Originally posted by smic717394 View PostWhats your wifi and BT? this kernel have MT59315A Wifi & MT6622 BT
mo123 sent info about drivers:
Mediatek MT7601 KitKat Wifi Patch
http://www.mediafire.com/download/hr...T7601_V2.0.rar
Can you add them?
I will test it if you could do that.
Regards,
Benobi
Originally posted by imaddiced2u View PostThanks smic, you are very accommodating. It is very much appreciated!
I'd be interested in trying a kernel with a low end cpu frequency of 312.
I guess I'm stuck at a max of 1.4GHz, I figured that my cpu was locked. I always found it odd that my other MK809III, same model, same vendor and bought at the same time, will go up to 1.7GHz although I run it at 1.6 GHz via No-frills CPU control.
THis is a full range kernel. CPU 312 - 1800, GPU 133 - 600 and DDR 200 and 667
Can you add them?
Regards,
Re: MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
Regards,
Benobi
Mine are:
Wifi: MT5931SA
Bluetooth: MT6622N
I would like too a firmware with native 1080p kernel and kitkat
Can you build it please?
Thanks in advance
http://www.mediafire.com/download/fa...kernel_1.8.img
With D33's kernel, no gpu no ddr overclock, there was more options for HDMI output:
1080px60
1080ix60
1080px50
1080ix50
1080px24
It is important for us, this 1080i version, since all others have a problem with picture and sound flickers, which is related with more power needed for 1080p range.
Is it possible to compile kernel which would have 1080i, this i is very important, with no gpu or ddr overclock, just range 312-1608 for cpu, with correct vsync and other stuff of yours.
I use your kernel with Neo's 3.1 version of ROM, which is stable so far.
There are currently 2075 users online. 1 members and 2074 guests.
