MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
I just flashed this rom in one MK809III (with old wifi Realtek Chipset RTL8188ETV and BT RDA5876) the WIFI and BT doesn't work but I use one small USB hub with Ethernet adapter and it WORKS GREAT!
I flashed the rom completely stock, got one error saying no bootloader, but after I edited the name of the loader in the ROM folder to RK3188Loader(L)_V1.04.bin it flashed great.
Speed: GREAT!
Antutu Benchmark: 16285
USB Keyboard: Works fine
Re: MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
Originally posted by makelele View PostI just flashed this rom in one MK809III (with old wifi Realtek Chipset RTL8188ETV and BT RDA5876) the WIFI and BT doesn't work but I use one small USB hub with Ethernet adapter and it WORKS GREAT!
Speed: GREAT!
USB Keyboard: Works fineFor all your computer problems...
http://www.salvamipc.es
Originally posted by makelele View Postcan you make one for the old wifi (if possible)?
Great rom!For all your computer problems...
Originally posted by imaddiced2u View PostIs anyone else having this issue? XBMC Gotham often crashes randomly while opening a movie, reopen XBMC, run same movie and it plays fine.
Originally posted by imaddiced2u View PostI put V2 on my second MK809III with a T CPU today. I used the 1.8 GHz full range kernel. It show a clock range of 312 MHz to 1.416 GHz. AnTuTu result was 15334 while my other MK809III with T CPU is still running V1 and gives an AnTuTu result of about 17000.
I wonder why there is such a difference?
EDIT:
I put the V2 ROM on the other MK809III and it still gets 17000 on AnTuTu.
Interesting to know what the problem is?
Other ROM overclock up 20000 AnTuTu.
If want you want is high score its easy, I can make a kernel CPU 1.2-1.8 GPU 667 and DDR 776 and increase the voltage to 1.45. This will increase your score but will reduce your units life.For all your computer problems...
I can't understand why I get such different AnTuTu results, 15,000 versus 17,000 even though they both have the same clock speed.HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
There are currently 2966 users online. 1 members and 2965 guests.
