MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
Yes. use the system.ini from post 8 iy has more drivers for keyboard and remotes.For all your computer problems...
http://www.salvamipc.es
Originally posted by smic717394 View PostSo you using somebody else rom but you want me to do the kernel for you. Jeje, here you have it
http://www.mediafire.com/download/gff4hpwff89c887/kernel_more_frq.img
Now you should have:
1920 x 1080p 60Hz
1920 x 1080p 50Hz
1920 x 1080i 60Hz
1920 x 1080i 50Hz
1920 x 1080p 30Hz
1920 x 1080p 24Hz
1280 x 720p 60Hz
1280 x 720p 50Hz
720 x 576p 50Hz
720 x 480p 60Hz
Now, not all the resolution will appear in the list unless your TV can support it. So unless you have a TV that supports 24Hz or 30Hz, you will not see it in the list. If you have it in the list then you can select it, but the image will refresh slower about 24 times every second instead of 60 times.
This is great for watching movies in 24Hz, not so great for the UI. The User interface will appear slower, this is normal behavior.
I admit that I am too lazy to install all my applications after change the ROM. That is why I wanted just a kernel to speed up process remaining on current ROM and all installed applications.
Another one, I have a problem to change Parameter 2 to 4, since this 4 would not boot.
Not a big problem, I can live with 2Gb of memory for applications.
And another one, Antuntu Benchmark crashes on CPU Integer check, somewhere on 14% or so. Any suggestions would be welcomed.
Re: MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
And another one, Antuntu Benchmark crashes on CPU Integer check, somewhere on 14% or so. Any suggestions would be welcomed.For all your computer problems...
Originally posted by smic717394 View Postill have a look at the parameters. Not sure. maybe your pushing the cpu too much and antutu crashes. use no fril and limit the cpu to say 1.4 and try again. Ask PolloLoco if he has this problems. , i dont have a 809III
Originally posted by Dzigi.Bau View PostYup, I tried that to decrease it to 1.4 still reboting on testing CPU integer. What do you think, is it ROM possbily making crashes of Antuntu or it is lack of power energy to make CPU pass test.
I'm using this full range kernel. CPU 312 - 1800, GPU 133 - 600 and DDR 200 and 667 http://www.mediafire.com/download/fa...kernel_1.8.img that smic was kind enough to compile for me.HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by imaddiced2u View PostAnTuTu completes without error on my 809III. Although my cpu is a T and seems to be locked at a max of 1.4GHz. I just ran it again. This time it resulted in a score of 17064.
Originally posted by PolloLoco View PostWith that score at 1080p, are you sure you're locked at 1.4ghz? Is that what antutu reported? Antutu clearly shows me 4 cores at 1.6ghz.
My other MK809III would clock to a max of 1.8 GHz when I was running Neo1.7 + SAM 1080p Kernel - CPU @ 1.8GHz, RAM @ 1.2GHz kernel but AnTuTu would crash at about 30%. but with the case off, Antutu completed with a score of 19842. I placed a fan so it is blowing on the heat sink. Antutu scored 19937. I used CPU Master to cut max clock to 1.7Ghz, with the case back on AnTuTu completed with a 19094. Unfortunately that one had a video display problem at 1080P right out of the box and I returned it.
The replacement MK908III has a T cpu and has neomode's 3.1 ROM installed on it right now. I plan to put smic's ROM on it when I get time. I'll report my results after I get it done. This one came with a thermal pad instead of a heat sink.
smic717394: I was looking through some of my old posts and was reminded that this MK809III clocked at 312Mhz-1608Mhz, with the SAM 1080p Kernel - CPU @ 1.8GHz, RAM @ 1.2GHz kernel and the Neo1.7 ROM. Antutu scored 18310 on that setup.
Any thoughts on why I can't get past 1.4GHz now?Last edited by imaddiced2u; 03 July 2014, 02:44.HK1 Pro Plus
FlowFon F1
MXQ Pro+
R-TVBOX Mini+
MK809III
I have updated the ROM on page 1.
Thank you.For all your computer problems...
Originally posted by imaddiced2u View PostNo, Thank You for your continued efforts.For all your computer problems...
in kitkat yo go to your home screen keep pressed few seconds and you will get a new menu...you will see itFor all your computer problems...
Originally posted by Dzigi.Bau View PostYup, found that.
Man, it runs so fast.For all your computer problems...
There are currently 2820 users online. 0 members and 2820 guests.
