MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
Re: MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
Originally posted by Benobi View PostFor all your computer problems...
http://www.salvamipc.es
Just pointing out a very minor issue, icons disappear after rebooting. 2 on the bottom right and the one I put on the main screen.
Before reboot
[IMG][/IMG]
After reboot
[IMG][/IMG]
No need to fix for me, maybe fix in future release.HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by PolloLoco View PostBe careful though - that Kernel is less compatible than SMIC717394's. I installed the kernel you linked on several sticks, and it only booted for kitkat on my RK3188T sticks, ironically, not on the true RK3188's.
The kernels that Neomode and SMIC717394 are using for their Kit Kat Roms are the most compatible. Especially when you factor in SMIC's audio out fix for certain TV's. My best friend just called me yesterday, because he got no audio out from the stick I gave him. I had installed Quickshot on his stick - I'll replace it with this ROM, and SMIC's excellent audio-fix kernel. The only concern I have is that the Quickshot kernel had unlocked his RK3188T stick to 1.6ghz+, I'm not 100% positive that SMIC's kernel will do the same. . .
Besides that - some of you folks are focusing too hard on benchmarks as opposed to real life benchmarks. Before this ROM and Kernel - I was using SMIC's MK902 1080P Jellybean ROM. Antutu was only reporting 13000! It was, however, reporting a 1.6ghz clockspeed. But it was obvious that the ROM was much faster than stock, or competing custom ROMs in gaming and video. Since using SMIC's ROM - I've been streaming 1080P videos without a problem (at 1.4ghz, playback was stuttery) and getting excellent video game play. I suggest focusing more on real life benchmarks than Antutu. But if you're getting unsatisfactory performance, then by all means look around for a better option.
But I noticed that when 1.6MHz system runs faster.
Programs and browser open and run faster.
I do not want highly overclock stick, 1.6MHz on cpu is enough.
But with this firmware works fine network.
Video Online and movies on a home network are almost without stopping.
Of all the firmware from this forum is the best IMHO.
THANKS smic717394 big THANKS !
Originally posted by imaddiced2u View PostJust pointing out a very minor issue, icons disappear after rebooting. 2 on the bottom right and the one I put on the main screen.
Before reboot
[IMG][/IMG]
After reboot
[IMG][/IMG]
I can confirm the problem, although is not ROM related. The problem is the Launcher itself, it coluld be because we are reducing the dpi. The fix is simple you can install nova launcher.
I will release today a new ROM and change the default launcher with Trebuchet from CM11. I tested and with Trebuchet is fine.
Also would you guys like me to add the initial setup? When you first flash the box the initial setup is where it ask you to choose language, zone, wifi, so by the time you done the only thing you have to change is the resolution.
Thank you and sorry for the trouble.For all your computer problems...
Originally posted by smic717394 View Postwhat error you get? you must have install busybox and pyton. i cant do it because i dont the unit to try it. Ill try something else.
insmod: init_module '/system/lib/modules/user-gpio-drv.ko' failed (No such file or directory)
Even when i try to dump i see:
/system/bin/sh: dump: not found
What to do?
Please help.
Regards,
Benobi
Thanks, it's really not a problem.HK1 Pro Plus
FlowFon F1
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by imaddiced2u View PostI only just noticed it and thought I would mention it.
It also happened with Smic's Jellybean Mk902 rom.
It's definitely not a problem, just something nice to have if you ever decide to update the rom, like exfat support. If it were up to me, I don't like the initial setup and wouldn't include it. I sometimes install roms on friends' sticks and don't want to fill in their info, I just want to see if the stick boots and sideload some apps.
Originally posted by PolloLoco View PostThat's the same minor bug I pointed out earlier in the thread, but was too lazy to take a picture. ☺
Ok, check first page for the new romFor all your computer problems...
What to do?
Please help.
Regards,
Benobi
install a root file explorer and copy the user-gpio-drv.ko to lib/modules
cgech this link for the tools.
Originally posted by imaddiced2u View PostWorks excellent. Many thanks.For all your computer problems...
SMIC: Spectacular work! V2 runs like a top with the default kernel on my RK3188 MK802IV AP6210. Im sure it will only improve with the 1.8ghz kernel. Video playback is smooth, network is quick and stable.
Thank you, SMIC!
Sent from my SGH-I337M using TapatalkPlease post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
Originally posted by makelele View Postplease please release for the old mk809III wifi.
Please
What unit you have and where u got it fron so I can get a similar one.For all your computer problems...
There are currently 2342 users online. 0 members and 2342 guests.
