The Time has come we have Build our own Android TV Box for you.
Here are the Technical Specs of our Box.
Processor — Rockchip RK3188 (4x Cortex-A9 cores @ 1.6GHz) with 533MHz Mali 400 MP4 GPU
RAM — 2GB DDR3 SDRAM
Flash:
Internal — 8/16 GB NAND flash
Expansion — SD card slot (supports up to 32GB)
Network:
WiFi — 2.4/5GHz dual-band 802.11 b/g/n; external antenna (supplied)
LAN — 10/100 Ethernet Base-T (RJ-45)
Bluetooth 4.0
USB — 3x USB Host ports
A/V ports:
HDMI v1.4 — full HD; 1080p@30fps
A/V output — 3.5mm jack
S/PDIF out
Multimedia compatibility:
Video decoding — MPEG-1, MPEG-2, MPEG-4, H.263, H.264, AVS, VC-1, RV, VP6/VP8, Sorenson Spark, MVC 1920x1080p@60fps
Video encoding — H.264, VP8, MVC@1080p
Audio containers — MP1, MP2, MP3, WMA, WAV, OGG, OGA, APE, FLAC, AAC, M4A,
Images — JPG, JPEG, BMP, GIF, PNG, JFIF; up to 8192 x 8192 resolution
Streaming protocols — DLNA, Wimo
Power:
5V DC @2A wall plug-in power supply (included)
Consumption (measured) — 3-4W active; 2W idle; 1W standby
Dimensions (measured) — 160 x 117 x 26mm (6.3 x 4.6 x 1.0 inches)
Operating system — Android 4.4 Custom Version by Freaktab.com included Custom Kernel and System
The Android Kernel and the System will be Build from Source means no Modded Firmware.
Also, you will get Community Support from Freaktab.com and also Firmware Updates.
This we will Guaranty for min. Of 2 years!
Ray
