You can free up memory on limited memory systems - so if you're using systems with a small amount of nand storage then you can grab some memory back by doing the following. To do this you just need to click on "Ultimate xbmc" on the main screen then on "install more addons etc" - then click on "Purge packages" and then on the "clear cache" button, this should free up some memory.
Hope this helps.
