what's changed with v1.5.
-removed superuser, only supersu now.
what's updated.
gmail
supersu
google play
what's added.
init.d support : fully working , not just added the folder.
replaced services.jar with the tweaked v6 supercharger services.jar.
replaced init.rc with V6 supercharger init.rc
v6 supercharger build.prop tweaks added too the build.prop.
ps.
some off you should say , must i install v6 supercharger on this rom.
now the choise is free.There are many tweaks builded in the rom.
you don't see difference when you install it.
someone say if apps installed too internal sd they won't work after reboot the tablet.
after installing these apps just replace them too the tablet, then your fine.
that are the reported apps homerun Battle 2 , Aldiko , MMA News , MMA Torch,archidroid
sow stop talking now and let's flash it.
here's version 2
ROM -> Arnova 10b G3 - SnakeKiller 2.0 - ICS 4.0.4 EXT4, CWM, initd (191 megs)
