I wasn't aware this was a microphone, I assumed it to be the IR receiver. Nice!
R89-Hardware/Thermal/case issue feedback here
Originally posted by Arbelzapf View PostThere are solder points for an unused USB port to the left of the microphone at the front of the board. Feel free to solder a cable on and connect a webcam. Only needs a whole in the case.
Downloaded Vega S89 Profile to my Harmony Remote , IR reception is terrible !
Due to interesting design of the Top Casing IR LED blocked almost 60-70% !!!
Board should be mounted Lower if possible or a Bigger IR Window is essential...
TBH I don't like the Casing at all cos back I/O part also is very problematic , its quite hard to insert HDMI cable etc.
Originally posted by TMx View PostDownloaded Vega S89 Profile to my Harmony Remote , IR reception is terrible !
TBH I don't like the Casing at all cos back I/O part also is very problematic , its quite hard to insert HDMI cable etc.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by oman View PostThe real Debug port:
which kind of cable or which way do you use to connect to this really small tiny spots at back of the pcb?RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View Post... but the kernel doesn't determine the CPU temperature... always at 2°C... a really cool device...
[ATTACH=CONFIG]7726[/ATTACH]
cat /sys/class/hwmon/hwmon1/device/temp0_input
I test it running CPU Prime Benchmark,after several mins,then:
root@rk3288:/ # cat /sys/class/hwmon/hwmon1/device/temp0_input
102
But still running...
Originally posted by no_spam_for_me View PostMaybe it seams so, this kernel/SoC also know thermal throttling?
Because after ~15 minutes at 100% cpu usage, it begins to throttle, BUT we talk about "after ~15 minutes" and not about ~1 minute like the s802AND not so often happens (also not after one more 10 minutes)
Unbelievable!
[ATTACH=CONFIG]7727[/ATTACH] [ATTACH=CONFIG]7728[/ATTACH]
The case, especially at the bottom, gets really warm/hot.
At the middle of the second picture you can see what ?maybe? happens if I lift a little bit up the case: less thermal throttling
So I think you really should use more space to the surface (I place the box at a glass table)...
BTW:
At my stress tests at s802 (http://www.freaktab.com/showthread.p...-Test-Scenario) I had the problem, if I switch between the apps, they may crash (e.g. 'StabilityTest (ROOT optional)' => classic test) or reset the GUI (e.g. 'System Tuner Pro' => monitoring) so I have to know how to handle it (at which moment switch to which app)...
BUT not at the RK3288 (ok, the curves may pause BUT no crashes)...?
Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by 4WheelSpyder View PostFor in case you are not aware of this feature. After opening the unit (only the two Philips screws at the back) I noticed the microphone in the cover. So I tested it with Ask Google, Sound recording and Skype, and it works nice and clear. Now just to populate the camera sensor that could go with it.
Originally posted by 4WheelSpyder View PostI wondered if that USB port is active, maybe oman could tell.
TBH I don't like the Casing at all cos back I/O part also is very problematic , its quite hard to insert HDMI cable etc.Originally posted by ENDRJUPL View PostI can confirm that. The spdif cable is not "in" all the way too due to the design....We'll take care about it.THX.
Originally posted by no_spam_for_me View Postsuch as Easter
which kind of cable or which way do you use to connect to this really small tiny spots at back of the pcb?Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View Post... Tom,could you do the Stress test Scenario for R89?
I have done it for ~2 hour and everything is fine (instead of the s802 ) and the result is the same as my quick shot I had posted, so I have no idea what I should write instead of "Unbelievable!"
OK, I will see what I can doRK3288 Devices
Originally posted by oman View PostIt's a UART2USB device to connect to PC for debug message..RK3288 Devices
There are currently 1958 users online. 0 members and 1958 guests.
