R89-Hardware/Thermal/case issue feedback here
Originally posted by clarkss12 View PostI just flashed your update (September 4), still no sound from HDMI through Harmon Kardon receiver.
1.Select Setting->Sound->Default Output, make your Receiver and TV the max volume,Play a normal video(No Dolby/DTS) via Stock RKvideoplayer/xbmc ,can it sound out?
2.Select Setting->Sound->HDMI Bitstream, make your Receiver and TV the max volume,Play a Dolby/DTS video via Stock RKvideoplayer/xbmc ,can it sound out 5.1?Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
But on a side note, this update fixed the video problem I had with your 108k4 update.
So, video is great
Ethernet is great
When the audio through HDMI to A/V receiver is fixed, you will have a winner.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostTried both of these suggestions, with my receiver volume maxed out, still no audio.
So, video is great
Ethernet is great
Appreciate if you can give me the dmesg and logcat...for the first optionEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View PostOkey,waiting for other guys' feedback...then let me think about the next step..
I tried an app to get the info you need. Here is the Dropbox link for my file. Hope it helps.
https://www.dropbox.com/s/oa4o0lnw82oj25s/2014-09-05_00.26.zip?dl=0Last edited by clarkss12; 05 September 2014, 05:33.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostUnfortunately, I can't get my computer to connect to this box...
I recognized that mine doesn't really fits to the port (try to use it to recharge a remote (minix m1) but lost often the power if I touch the cable)...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View Postare you using the OTG-adapter you got with the box?
I recognized that mine doesn't really fits to the port (try to use it to recharge a remote (minix m1) but lost often the power if I touch the cable)...MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Not had time to test the new downloaded firware proparly but stock xbmc with hdmi arc transcoding enabled reciever says dolby with 5.1 sound but sound is there only 0.1 seconds every 1 seconds.
DTS is also wrongly shown as DOLBY on my reciever with transcoding enabled.
Without transcoding enabled sound is normal stereo and my reciever does not say dolby or dts.
Did not yet test with SPMC but the with 108 the same settings both HDMI and SDIF give hissing sound only. There is strange different behavior between sound in stock xbmc and spmc!
Both default and hdmi bitstream tested with same result.
EDIT:
SPMC now tested, transcoding enabled hissing sound both dolby and dts.
Transcoding not enabled dolby is normal stereo and dts gives hissing sound.
With stock xbmc MASHUP, DEMON88 1080p videos are not entirely smoth and that could be part of the reason why surround is not working proparly.
With xbmc get green screen when movie has played 10 minutes with some DEAMON88 (Mashup) for example Movie named Heatstroke.
With SPMC same videos runs much smother and conntinues to play after 10 minutes without problems.Last edited by ssspacman; 05 September 2014, 22:02.
Originally posted by ssspacman View PostNot had time to test the new downloaded firware proparly but stock xbmc with hdmi arc transcoding enabled reciever says dolby with 5.1 sound but sound is there only 0.1 seconds every 1 seconds.
EDIT:
With SPMC same videos runs much smother and conntinues to play after 10 minutes without problems.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Appreciate if you can give me the dmesg and logcat...for the first optionMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
回复: R89-Hardware/Thermal/case issue feedback here
Originally posted by clarkss12 View PostOman, Did you down load the dmesg and logcat I posted for you at my Dropbox?
来自我的 GT-I9300 上的 TapatalkEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
There are currently 1977 users online. 0 members and 1977 guests.
