Tested 9 files and confirmed WORKING slight judder but only slightly and rechecking some files to see if its the encoding rather than anything else.Great news indeed.
R89-Hardware/Thermal/case issue feedback here
Originally posted by Talas View PostHDMI 2.0 3180*2160 50/60Hz:Tested 9 files and confirmed WORKING slight judder but only slightly and rechecking some files to see if its the encoding rather than anything else.Great news indeed.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View PostI modify something...will upload the update.zip..
Here is my test result:
Firstly,you should select the right option:
For spdif passthrough,select the second one..
For HDMI passthrough,select the third one..
Select all this audio passthrough options.
Then,
If not passthrough way,no Dolby/DTS can sound out by stock rkvideoplayer
If spdif passthrough, stock rkvideoplayer cant decode DD+ sound..but with xbmc is fine..
If HDMI passthrough,all seem fine..
Pls check it...I dont want push to OTA,just a test zip..
Here to download->update.zip
Put the update.zip to sd card or eMMC via usb OTG..then it will find it..
BTW,the HDMI 2.0 3180*2160 50/60Hz is also added,Talas ,pls check this.
For HDMI passthrough issue...because I tested with the same FW/HW..it's almost ok..
Hope everyone of 20 who have the AV receiver can test it and give me a little more info..
1. I upload an AC3 videos,pls test this:
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
2.About the FW version,pls update the latest 108k4 by OTA,then update another zip:update.zip
3.And the Settings to be proper..Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View PostOkay,thank you..Hear about you go to IFA, what do you think about smart watch,if we design one ...
Originally posted by oman View PostFor HDMI passthrough issue...because I tested with the same FW/HW..it's almost ok..
I wish I had better news, but audio is still dead on my receiver. Just to make sure there's no miscommunication, this is what I did:
- I downloaded the update.zip
- Moved it to the root of the internal sd-card
- Rebooted
- I was prompted with a dialog that an update was ready, so I chose to install it
- When it was done installing, I opened the Gallery app and played the video you linked ( Sound Setting : Bitsream) --> No Sound
- I switched the setting to default and tried again ->still no sound.
The front panel of my receiver usually shows the current audio setup (ie. the channels it's receiving) and that part is completely blank when the R89 is active. This is probably to be expected given the nature of the problem, but I just thought I'd mention it anyway
Tested file. No improvement, same results as before. XBMC HDMI transcoding sound 0.1 seconds every 1 seconds. In SPMC hissing sound. Transcoding through sdif optical perfect 5.1 dolby.
Uploaded on youtube. Notice surround system should only say dolby a few seconds.
First SPMC hdmi arc.
Second XBMC hdmi arc.
Third XBMC connected with optical.
Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
http://www.youtube.com/watch?v=3MO3UFgVzNM&list=UU_dcS6NEUCKQ2l1ubTv6AlwLast edited by ssspacman; 09-10-2014, 14:52.
回复: R89-Hardware/Thermal/case issue feedback here
Originally posted by ssspacman View PostI will test that file later today. Is it a new update.zip or the same file from last week?
来自我的 GT-I9300 上的 TapatalkEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View Post... If they communicate to fail,then the BOX will output DVI,you can see it from LOG,that'll be no sound to come out.
Is there a name for this query/configure feature in HDMI? Can the firmware of the R89 be configured to "force" a setup without receiving the configuration of the TV via the receiver?
Or, is this no longer an issue? (Too late to the party?)Last edited by Tybalt39; 09-11-2014, 00:03.Tablet History:
Pipo M8 Pro (current)
NextBook W8.1 (sold)
Asus TF300 (sold)
Hyundai A7 (sold)
Nextbook 7" (sold)
Originally posted by goldenrod View PostThe same as others for me. The test Dolby file plays in 5.1 surround over spdif using the stock media player, but is knocked down to stereo over HDMI.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostWhat brand and moldel is your receiver?
On XBMC, there is no Dolby D or DTS using passthrough settings on the same files. It folds it down to stereo.
There are currently 3082 users online. 6 members and 3076 guests.
