Beelink R89/UBOX ROM/Tools release
Originally posted by TMx View PostThis worked for me but Build Number 104k4 in settings ,107k4 in About Device
In the original setting is right..
Next time we will correct it..
Do you have any other feedback about R89?Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by clarkss12 View PostI followed your new instructions twice, but still "no devices found"
[email protected]
Add me and do quick communication.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Easy way to "MASK rom mode"RK3288 Devices
- Overview BOX (LINK !)
Originally posted by clarkss12 View PostTMx, can you clarify a little more, thanks
thats it... you can install the new FW after PC (android tool)detects the R89 box ...
Originally posted by TMx View PostAs Oman suggested Instead of pressing reset button before connecting USB to PC, short those points by something like this
but thanks, will give it a try.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Just throwing that out there, connecting the R89 works more reliably if I do it this way:
- Connect the OTG cable to computer and R89
- Press the Button in the AV connector
- Plug in the PSU
The timeframe in which you have to connect the OTG cable (Or press the button) seems to be pretty tight, so -for me- it works more often (->all the time) if I reverse the order that Oman gave.
Originally posted by Arbelzapf View PostJust throwing that out there, connecting the R89 works more reliably if I do it this way:
- Plug in the PSU
The timeframe in which you have to connect the OTG cable (Or press the button) seems to be pretty tight, so -for me- it works more often (->all the time) if I reverse the order that Oman gave.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
STOCK ROM
Untouched stock rom 106k4 dump (at R89 2GB/8GB AP6210)
(Done before starting the system; first start up directly to 'boot loader mode')
'All in one' with configured 'RKAndroidTools v2.3' => you only have to press [Run] (and to have to wait)
I also include the ReadMe by Finless (THX Bob) how to dump and the meaning of the partitions.
Partitions: parameter, uboot, misc, resource, kernel, boot, recovery, backup, cache, kpanic, system, metadata, userdata, radical_update
BTW: 106k4 IMG only contains misc, resource, boot, recovery, system(also 107k4)
=> http://www.file-upload.net/download-....dump.zip.html
download via this symbol at the download-link =>
I also generated a 'All in one' for
recovery_TWRP (2.7.1.0)
(http://www.freaktab.com/showthread.p...tible-with-R89)
=> http://www.file-upload.net/download-..._TWRP.zip.html
and
recovery_stock (106k4)
=> http://www.file-upload.net/download-...stock.zip.html
(107k4 recovery.img http://www.file-upload.net/download-...107k4.zip.html)
BTW: keyboard at recovery FLOP (also M1, only IR which I don't get, I found one with working up/down but NOT [ok], hmmmm, aaaah, power on/off reacts as [ok]
Reboot_v1.2.2.apk is nearly a MUST to have
Next step: I will try to build update.zip versions for using by stock-recovery...Last edited by no_spam_for_me; 31 October 2014, 12:56.RK3288 Devices
ADB
I) What you need:
1. USB-Driver via Moborobo (http://www.moborobo.com/)
(BTW: needs internet connection to install driver AND keeps USB-drivers after uninstall)
2. ADB by neomode (http://www.freak-tab.de/neomode/adb.zip)
II) Prepare system(s):
1. Setup android
I've these settings in android
Settings -> [DEVICE] USB -> Enable Connect to PC
Settings -> [PERSONAL] Security -> Enable Unknown Sources
Settings -> [SYSTEM] Developer options -> Enable USB debugging
1a. Unplug power
2. Install USB-Driver via Moborobo
2a. Connect device via micro-USB-cable at OTG-Port at the device with your PC
2b. Plug power to your device (starts up automatically)
(2c. uninstall Moborobo)RK3288 Devices
OK FYI guys. I don't have the R89 yet but I do have the HPH box.
I was able to flash the 107K4 ROM to the HPH box and all works!
So this means it should also work the other way around
e.g. my finless 1.0 ROM for the HPH will work on the R89!
FYI R89 ROM is missing features like brightness and contrast adjust in display settings. My HPH 1.0 ROM has those.
no_spam, I have been trying to make a update.zip but no go!
I keep getting invalid package.
I have made 3188 update.zip files no problem! So RK changed something wither with the keys they used to sign zips, or the update binary in META-INF from 3188 will not work on 3288.
I have not tried it by booting into recovery I have just been using the built in update (it sees when update.zip is on sdcard and asks if you want to install it). This always worked on 3188.
Anyway, if you make any update.zip progress let me know but I have a feeling we need Oman to give us the keys or META-INF folder for 3288.
There are currently 1552 users online. 0 members and 1552 guests.
