Beelink R89/UBOX ROM/Tools release
Originally posted by hellomysons View PostMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Hi Cladrss12 ,
i find it in the A/V hole , but i still can't connect to usb same as recovery mode ,
when i press stick in the A/V hole ,
and then plug in psu , the output screen always blue and nothing
how can i to fixed it , thanks
Originally posted by clarkss12 View PostInside the A/V hole (you can't see it) there is a tiny button switch. If you take a round toothpick and GENTLY slide it into the A/V hole, you will feel a "click".
Originally posted by hellomysons View PostHi Cladrss12 ,
i fined it into the A/V hole , but i stall can connect to usb same as recovery mode ,
when i press the A/V hole , and plug in psu , the output screen always blue and nothing
If you press the reset inside the A/V during the device is connected to the PC (via OTG) then you don't see any screen output, because the device goes to the 'bootloader mode' which is need if you want to flash something using the PC tools...RK3288 Devices
- Overview BOX (LINK !)
sorry , my browser plugin auto choose word and cause many typo ,
the problem is that my computer can't detect device via otg ,
Originally posted by no_spam_for_me View PostSorry, it is really difficult for me to understand what you do:
Because you didn't answer my question I think you are not back at stock rom...
(BTW: I don't know how you handle to wipe the system-partion (Because of TWRP?))
That means at the moment OTG will be the only way...
Are you sure the OTG cable is OK?
(BTW: I find out that at my adapter the contacts are not so good)
Have you any other cable you can try?
Another PC?
...RK3288 Devices
ya , i think so
ya , i wipe my system partition because i want to erase TWRP
i think OTG Cable maybe ok (i have two and both test),
cause another r89 box can read storage via OTG cable
i just have a usb cable , i can't sure it is ok or not , but it is new ,
i will buy another one to try again tomorrow,
Another PC?
i test it with three nbs , i think it should not be pc problem
My mistake, I didn't mean "not back at stock rom" but mean "not back at stock RECOVERY"...
And I think you was able to wipe the system with TWRP (because stock recovery doesn't know somthing like this)....
RK3288 Devices
BTW:
But it was able in the past, because you had flashed TWRP via OTG...
So I have no idea which other parts you had (also) killed (or the flashing of TWRP killed these unknowing parts)...RK3288 Devices
If it is an update (zip-file):
a) download file and rename it to update.zip
b) copy the whole update.zip file to micro sd card or usb driver
c) power on your device and then insert the sd card or usb drive. The system will find a update and ask if you want to do the update, click yes. The device should do the update and reboot.
If it is an image (IMG-file):
Originally posted by Finless View PostOK the stock recovery CAN flash the ROM Oman uploaded. e.g. the large IMG file.
Instructions:
1) You will need an IR remote. The one I got with the HPH works but the power button is select not the OK button.
2) download OMan's 107K4 from the posts here.
3) rename it to update.img
4) copy it to SDcard.
5) reboot into the recovery menu (using reboot app or whatever).
6) from the menu select "update rkimage from external storage".
7) It will flash the ROM then select reboot.
If you want to erase, then select factory reset before selecting reboot.
BobLast edited by no_spam_for_me; 01 October 2014, 12:52.RK3288 Devices
Hello. Help please. The last hope for you.
my Beelink R89 turns on and logo appears on the TV and on beelink not download.
Instructions:
5) reboot into the (using reboot app or whatever).
This manual does not help. How can I get into the recovery menu and make a wipe?
Originally posted by Lexxxus View Post... How can I get into the recovery menu and make a wipe?
1. power off the device
2. press the reset button with e.g. a toothpick
3. while pressed reset button power on ...RK3288 Devices
Originally posted by no_spam_for_me View PostThere is a reset button inside the a/v hole...
It works on your Beelink r89?
On my Beelink its not work.
Any more options?
Thanks.
Try this to reboot to recovery:
I'm missing the "Backup&Update" app (or "Update&Backup") at an older 109k4 ?RK3288 Devices
Originally posted by no_spam_for_me View PostTry this to reboot to recovery:
@oman
If beelink does not load completely - install apk impossible? Right?
There are currently 4677 users online. 1 members and 4676 guests.
