Beelink R89/UBOX ROM/Tools release
Originally posted by wolfheart79 View PostHI OMAN . when its ready official rom 111k4 , ??
thank u
But as well into the 110k4, the whole system suffers of micro-stutters not only video playback, very noticeable when "live wallpapers" are being used (i.e, magic smoke). It´s a matter to polish, fine-tune the stock rom for next release, hopefully we can enjoy the FW very soon.
I had noted too that the AV port (analog NTSC or PAL) on 110k4 does not work.
PS: One more problem detected it´s with the Logitech C525, regarding to the stock camera app on photo/picture mode works, but when it´s switched to video mode does not work, crash the app; it´s required to clean cache and data from the app to can be able to run it again.
But I had to say to you as well thanks for a great product as Beelink R-89 is, HDMI v2.0 fully functional with all HDMI modes available including 4K- 60 Hz; and I have criticized before the shape of the box, but as soon had arrived to my hands I had started to like it, looks fine; the black bright polished front looks distinguished. I think this is the best ratio price/performance/quality/support on any TV box that I had owned so far. The built-in Mic works Ok, and the two colors led on this PCB v3 are great pluses on this product. Thank you.Last edited by BTR11; 13 December 2014, 04:54.
:RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostIf I'm not wrong tested it with 110k4, but it only works if I power on the box ONLY connectet by AV (not also HDMI) and power on means unplug/plug PSU...
Originally posted by BTR11 View Post... It´s like this AV port on R89 it´s just a hole doing nothing, may be because of had nit bieng properly set up into FW??.
=> http://www.freaktab.com/showthread.p...l=1#post246565RK3288 Devices
Originally posted by no_spam_for_me View PostNo, no, also not becuase of the "just a static noise"
I just got my Beelink R89. I tried to update the firmware but can't seem to get it detect. I installed DriverAssistant 4.1.1 on my Windows 7 PC. After the driver installed, I reboot the PC. I plug in the power cable, press the AV button and heard a click and plug in the OTG cable to my PC. The PC detect the box but it detect as "unknown device". AndroidTool_Release 2.3 and FactoryTool v1.35 doesn't detect my Beelink R89. Is there anything else I need to be able to flash my Beelink R89?
1. plug in the OTG cable to PC
2. press the micro-switch inside the AV hole (you will hear a click) and leave it pressed
3. plug in the power cable / PSURK3288 Devices
Originally posted by duckymcse View PostI just got my Beelink R89. I tried to update the firmware but can't seem to get it detect. I installed DriverAssistant 4.1.1 on my Windows 7 PC. After the driver installed, I reboot the PC. I plug in the power cable, press the AV button and heard a click and plug in the OTG cable to my PC. The PC detect the box but it detect as "unknown device". AndroidTool_Release 2.3 and FactoryTool v1.35 doesn't detect my Beelink R89. Is there anything else I need to be able to flash my Beelink R89?
Firmware version 111k4110_beelink is available at the beelink site:
http://www.bee-link.com/en/article.php?id=136
Chancelog from Beelink Website:
1.Support ext4 format U disk and exfat sd card
2.wifi AP6335 perameters adjustment
3.Optimize USB camera
4.Upgrade skype verison
5.Add usb storage device infomation in Settings
6.Optimize RK Vedio player
7.Fix the incompatible problem of some apps in Google Play
8.Fix some 4K H.265 problem
9.Fix some screenshot bugs
10.Update bule ray library
11.HDMI to support cec
12.Open the ip multicast and nfs
13.Otg interface self-adaption to be host or device
14.Browser mode change to android
15.WiFidisplay support
16.New xbmc version,support hdmi passthough betterLast edited by NetMax; 26 December 2014, 10:31.
Originally posted by NetMax View PostFirmware version 111k4110_beelink is available at the beelink site:
16.New xbmc version,support hdmi passthough betterEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
edit:
flashed both and the only thing diffent i noticed is the bootlogo and splash screen. i prefer the google tv logo and android bootscreen so i'll stick with the 6mb shorter oneLast edited by Elroy1; 26 December 2014, 13:30.
AW: NEW - Wasser Firmware V2.0.3 for Beelink R89/Tronsmart R28
Did you read: http://www.bee-link.com/en/article.php?id=136
Keep smile.
Gesendet von meinem SM-P905 mit Tapatalk 2
There are currently 1330 users online. 0 members and 1330 guests.
