please add to resolution 1600x1200!!!
Beelink R89/UBOX ROM/Tools release
Originally posted by mikiki View PostHi,
I'm only one to have this problem ?
"What about the 1080p24hz ?" what ever this question means, but maybe you have the same problem as me => http://www.freaktab.com/showthread.p...l=1#post234430 till post 28...RK3288 Devices
- Overview BOX (LINK !)
Movies are encoded at a number of frames / second (usually 23,976 img / sec, and the double framepacking 3D ) , concerts and documentaries to another (usually 29.970 img / sec).
The reader and the diffuser must therefore be able to change their frame rate ( framerate ) when reading so as to be the same (or multiple) of the frequency of film / concert / documentary .
Without this, images are skipped at regular intervals to catch frequency shift , giving a jerky appearance ( especially on sensitive traveling ) .
This player does not know change frequency ( while a xbmc option exists) , or out in 23.976 , which explains saccades
Sorry for my english (google tradution)
@yanik : thank you, i'm not alone !!!!!
today I received my Beeling R89.
But unfortunately I'm not able to connect the box with Android Tool.
I have tried both options, but I only get an unknown device in the device manger of my win7x64.
A manual update don't work be course windows says there is no valid driver available.
I've tries all the driver I found in the hole www.
I thought last chance and opened the box to connect the both holes together. But I have a different layout of the board. My board version is V3.1. Is it a new layout? I it the reason why I can't connect the box to Android Tool?
Please help me, I can't use the box with the stock image. It's terrible!!
Br
Ringli2k
Originally posted by Ringli2k View Post..But unfortunately I'm not able to connect the box with Android Tool.
Maybe you can try it this way:
start the driver-assistant as administrator and uninstall the previous drivers (right button)
then reboot windows
start the driver-assistant as administrator again and install the drivers (left button)
then reboot windows again
then follow the written instructions from post #1:
2.Open AndroidTool_Release_v2.3 (as administrator), then load the ROM;
3.Plug in PSU(Power supply unit),and push and hold the button in the AV hole,then plug-in the USB OTG cable..
4. After the tool show up 'Found One LOADER Device', click 'Upgrade'.
You should try to connect several times until the box is found. (My win7x64 found the box and the drivers on third try)
good luckLast edited by uli-hh; 22 January 2015, 22:53.
:RK3288 Devices
Br
Ringli2k
"3.Plug in PSU(Power supply unit),and push and hold the button in the AV hole,then plug-in the USB OTG cable.."
At my first connection there was same issue . Be sure for push the button in the AV hole (at the deepest position of hole) .
Originally posted by uli-hh View PostYou only need the the drivers that are installed with the Release_DriverAssitant from post #2.
then reboot windows
good luckOriginally posted by ytkrc View PostAre you sure about follow ? Did you hear "click" sound ?
I've installed the driver on two windows machines (win7x64 and win8.1x64) but always the same results. I've also changed the OTG and USB cable.
I push and hold the button in the AV hole and after 30sec. my PC recognizes an unknown device. It installed an windows standard driver. I have uninstall the driver several times but always the same result. Today I'll try it again with a winxp x32 machine.
Br
Ringli2k
THX
and maybe also have a look at http://www.freaktab.com/showthread.p...-box-read-this!!!!RK3288 Devices
Unfortunately also without success . :-(
I think something is different with the R89_V3.1_201401017 PBC.
I did it with different pc and operating systems, but I don't get the right driver installed.
The PBC connect with the GUID {36fc9e60-c465-11cf-8056-444553540000} but all the drivers are for {79DFC2A8-2574-493C-AE71-52958E41BB00}. Can you check with GUID your PBC connected?
In Germany is a other Box (S92) from Orbsmart available. I think it's the same box like Beelink R89.
Orbsmart published also a 111k4 Update. This Update must be flash from microSD card. Here is the update file: Update
I always thought that a update from microSD card isn't available for Rockship!?
Br
Ringli2k
I'm actually at x86\xp...
I don't think the "ClassGUID={79DFC2A8-2574-493C-AE71-52958E41BB00}" is the important part, but the "%Rockusb_DeviceDesc%=Rockusb_DDI, USB\VID_..." at the rockusb.inf...
At AIDA64
Code:Hardwarekennung USB\Vid_2207&Pid_320a&Rev_0100 2207 320A Rockusb Device Geräte ID 2207-320A :
Update via SD... yes and no... there exist the way via an update-script (also use at OTA) and also at recovery via something like update-rockchip (or so on) since the rk3288 using a IMG, BUT the img must be able to handle it (we also had the situation at Tronsmart, that the img which was designed for the burning-tool at PC, used at recovery, bricked the device...)RK3288 Devices
There are currently 2150 users online. 0 members and 2150 guests.
