Originally posted by Finless
View Post
Beelink R89/UBOX ROM/Tools release
Originally posted by clarkss12 View PostPost 188, but I am having a tough time downloading it. It started to download then stopped, will not connect again.
http://www.freaktab.com/showthread.p...ht=#post237837
Originally posted by Finless View PostDownloading now. I will post it to FT servers when done.
BobMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Installed the 110k version using the new drivers with the previous tool. The new tool was just "sitting" there - no feedback on the progress.
In relation to clarkss12 micro USB connection problem. This time I grabbed the USB cable that came with my Nexus 7 and the connection was very "iffy".
Apps not compatible and Keyboard lag/bounce
OK this is odd, no matter how much I edit build.prop to spoof thinks as well as the fingerprint, etc. I cannot get APPs to allow install and they say not compatible!
Trust I have tried everything in build.prop I could think of.
Prime example the Crackle APP says not compatible.
Makes me wonder how Google Play is now determining that?
Also Oman, there is something really wrong with the keyboard input. It's laggy for soft keyboard and when you have a external keyboard (Logitech k400 is mine) it will start repeating characters really bad!
Funny as this was an early bug on 3188 devices
Originally posted by Finless View PostIt's laggy for soft keyboard and when you have a external keyboard (Logitech k400 is mine) it will start repeating characters really bad!
Originally posted by Finless View PostOK this is odd, no matter how much I edit build.prop to spoof thinks as well as the fingerprint, etc. I cannot get APPs to allow install and they say not compatible!
Some hints->
1.http://developer.android.com/google/play/filters.html
system\etc\permissions\
2.The advice I can give out is using your external keyboard/2.4G Airmouse by OTG port.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View PostHi,Bob:
Some hints->
Totally forgot about that one.
Thanks for the reminder!
R89 broken again
Tried to install Firefly dual Android/Linux rom on my R89, it loaded but could only get to the Firefly screen. Tried just the Linux rom, but my R89 says "prepare IDB fail". Tried installing Finless rom, but same problem IDB fail. Not sure what to do next. I connect to my Windows 7 computer and it detects the device perfectly. Is this going to be a situation where I have to short two pins? I surely hope not, my vision is not very good.
Any help would be greatly appreciated.
Link to the rom I tried to install. I am not sure what caused the IDE to fail, I did do a lower format.
thanks
Ok, back working again. From Oman's first post he shows those two teeny, tinny holes, I guess it is the same as shorting two pins on the ram chip. Anyway, when I shorted those two pins and then held in the reset button as I powered it on, it showed as "mask rom", and I had never seen that before. Since I had no idea what I was doing, I started clicking buttons on the advanced tab. "ReadIDB", "TestDevice", "ResetDevice", ect. Anyway, after I got done clicking buttons, I removed the jumper I had in those two tenny, tinny holes and pulled the power plug. When I again held the reset button, and plugged in the power, it worked. So, I am back to Finless 2 rom for my R89. I may try again tomorrow to install the dual boot linux.Last edited by clarkss12; 11-13-2014, 01:01.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by 4WheelSpyder View PostPhew! Glad to hear you got it going again. May have to save this post of yours.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Well said bro. You saved me the trouble figuring stuff out once I start testing the dual boot and messing about.
Originally posted by clarkss12 View PostThanks, every time I mess up, I learn something new. But as my dear old departed mom used to say. Iffen you don't mess up, you ain't trying your best.The funniest thing about this particular signature of mine is that by the time you realize it doesn't say anything it's to late to stop reading it
BTW I formated a 64gb micro SD card fat32 and the r89 sees it 59.6 GB available. Not sure why its advertised as only taking up to a 32gb micro sd.?The funniest thing about this particular signature of mine is that by the time you realize it doesn't say anything it's to late to stop reading it
Re: Beelink R89/UBOX ROM/Tools release
Originally posted by ICU View PostBTW I formated a 64gb micro SD card fat32 and the r89 sees it 59.6 GB available. Not sure why its advertised as only taking up to a 32gb micro sd.?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 2384 users online. 5 members and 2379 guests.
