It's a little strange..
Beelink R89/UBOX ROM/Tools release
I have been trying for hours to get Android tool ver. 2.3 to find my device, but no luck. If I connect my rk3188 box, it says device found. I have followed your instructions, I connected the power and blue light is on. I pushed and held the micro switch (I can hear the click) inside the AV hole, then connected the micro usb adaptor that you supplied to the OTG port. I am thinking that perhaps it is a problem with the reset button (inside the AV hole). Perhaps you have more suggestions.
thanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostI connected the power and blue light is on
thanks
but if you then put the otg ,the box will power on..Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View PostNormal situation is blue light isnt on when you put the power...
but if you then put the otg ,the box will power on..MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Help!!! how to load rom from recovery mode
I accidentally wiped out my android operating system by installing TWRP. Could not get anything on the screen. Tried to use the Android tool to install rom, but could not get box to connect to the Android tool. Anyway, I finally got the UBox R89 into recovery mode. How do I install rom from this menu? I have box connected to monitor with HDMI cable and got into recovery menu by powering on the box, depressing the reset button (inside the AV hole) then depressing the start button for about 10 seconds. Now the choices are:
start system now
update from external storage
rkimage from external storage
update from cache
data/factory reset
cache partiton
recovery from system backup
what do I do now? I downloaded Oman's rom but have not installed it on micro sd card yet. Is this what I need to do? My card reader is not functional now, one will be here Thursday then I can copy Oman's rom to the micro sd card. Will that work?
Originally posted by clarkss12 View PostI accidentally wiped out my android operating system by installing TWRP. Could not get anything on the screen. Tried to use the Android tool to install rom, but could not get box to connect to the Android tool. Anyway, I finally got the UBox R89 into recovery mode. How do I install rom from this menu? I have box connected to monitor with HDMI cable and got into recovery menu by powering on the box, depressing the reset button (inside the AV hole) then depressing the start button for about 10 seconds. Now the choices are:
start system now
update from cache
data/factory reset
cache partiton
thanks
Do what I writed on the first postEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View PostI watched the video and logcat,and tried to find the root cause..
Next time I should really set a different log level. I only googled the very basics of grabbing a log through adb since it's been a year since I have done this the last time.
You have obviously seen all the exceptions caused by "com.mbx.settingsmbox" resp. "com.mbx.settingsmbox/com.mbx.settingsmbox.OobeActivity" (towards the end of the log).
I'm beginning to think I might get around the issue if I just delete/deactivate the app in settings. But that's not a real solution, of course (The real solution, of course, would be to wrap the whole app in a try/catch{} block.)
I hope you find the root of the issue. It's irritating that only my box seems to have this problem, yet it shows on a fresh install right through the flash tool. There's no way I could have broken something by changing settings/disabling apps/doing some root stuff.
I'll gladly try any crazy idea you might have and the box is always ready to flashIn the meantime, I'm back to stock.
Strangly I cant flash the rom
I did everything oman posted but the Androidtool just reports no device found.
I first thought that the USB (kable) is broken but it works fine on the OTG while in Android you click on connect to pc.
Hm...could it be that the button inside the AV-Out is broken ?
Is there another way to press the reset button...and why put it in the av-out ?
Originally posted by oman View PostMy ROM can only be upgraded by usb OTG,no SD card..
Re: Beelink R89/UBOX ROM/Tools release
Originally posted by clarkss12 View PostI have the same problem. I thought the same thing about a bad reset button in the AV hole. But the button is fine, I was able to get into the recover mode using that button. If you find a solution, I would like to know also.
thanks
Originally posted by Smokez View PostThe only way I could get it to show up as a loader device is via either the 2.1 or 1.37 tools linked here in Bob's backup guide. In one of those tools it lets you switch to loader then in the latest tool it should show up. Was temperamental though to say the least. http://www.freaktab.com/showthread.p...ew-RK-2-1-toolMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Is there another way to press the reset button...and why put it in the av-out ?Originally posted by clarkss12 View PostI have tried those also...... haha, I just cannot get this dang box to connect.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
There are currently 1915 users online. 0 members and 1915 guests.
