Maybe download my all-in-on and replace it with your dumps...
Beelink R89/UBOX ROM/Tools release
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostMaybe you can upload it at the Tronsmart-Sub-Forum...
http://www.freaktab.com/showthread.p...l=1#post221237R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Hangs on "Test Device Start"
Hi, I have a tronsmart R28 pro, and somehow I bricked it. I can not flash or erase with normal ways. I opened the box and found that the PCB looks exactly the same as R89, so I found the two pins besides the emmc component. I short cut these two pins, and the tool "Found One MASKROM Device". However, further operations always hang at the "Test Device Start" step:
Download Boot Start
Download Boot Success
Wait for Maskrom Start
Wait for Maskrom Success
Test Device Start
It hangs there for long long time, I think it won't proceed, forever.
Is my device severely damaged, even the MASK_ROM can't restore it? Please help me.
Thanks.
Originally posted by linuxerwang View PostHi, I have a tronsmart R28 pro, and somehow I bricked it. I can not flash or erase with normal ways. I opened the box and found that the PCB looks exactly the same as R89, so I found the two pins besides the emmc component. I short cut these two pins, and the tool "Found One MASKROM Device". However, further operations always hang at the "Test Device Start" step:
Download Boot Start
Test Device Start
Thanks.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View PostGive the right log in AndroidTool_Release_v2.3\Log\ to me,let me check.
16:33:45 600 AndroidTool v2.3.0.0 start run
16:34:37 595 Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0
16:34:37 896 Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0
16:34:37 896 Error:ResetDeviceProc-->RKU_ResetDevice failed,err=-3
16:34:52 911 Layer<1-2>ownload Boot Start
16:35:49 953 Layer<1-2>ownload Boot Success
16:35:49 954 Layer<1-2>:Wait For Maskrom Start
16:35:50 454 Layer<1-2>:Wait For Maskrom Success
16:35:50 455 Layer<1-2>:Test Device Start
16:35:50 455 Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0
16:39:15 122 Error:RKU_Write-->WriteFile failed,bRet=0,err=5,size=31,write=0
16:39:15 122 <LAYER 1-2> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-3),path=\\?\USB#VID_2207&PID_320A#6&7BDDD4C&0&02#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
16:39:16 122 Error:RKU_Open-->CreateFile failed,err=2,path=\\?\USB#VID_2207&PID_320A#6&7BDD D4C&0&02#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
16:39:16 122 <LAYER 1-2> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-1),path=\\?\USB#VID_2207&PID_320A#6&7BDDD4C&0&02#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
16:39:17 122 Error:RKU_Open-->CreateFile failed,err=2,path=\\?\USB#VID_2207&PID_320A#6&7BDD D4C&0&02#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
16:39:17 122 <LAYER 1-2> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-1),path=\\?\USB#VID_2207&PID_320A#6&7BDDD4C&0&02#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
16:39:18 124 Error:Layer<1-2>:Test Device Fail
16:39:26 112 AndroidTool v2.3.0.0 start run
16:40:49 156 Layer<1-2>ownload Boot Start
16:41:46 100 Layer<1-2>ownload Boot Success
16:41:46 102 Layer<1-2>:Wait For Maskrom Start
16:41:46 598 Layer<1-2>:Wait For Maskrom Success
16:41:46 599 Layer<1-2>:Test Device Start
16:41:46 599 Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0
ScanLog2014-09-14.txt output:
16:09:52 492 Error:EnumerateHubPorts-->DeviceIoControl failed,err=0x57
Thank you for the help!
1.Change another USB port on your PC or another PC;
2.Change one more better USB cable;Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
BUT, I did try to use a different USB port and cable, and after a few more times trying, it worked! I can't explain why, the first a few times it failed as before, then suddenly it proceeded more and failed, then finally it can finish what it should. Now it's completely back.
Thanks a lot!
Hi all ,
i am a new user , and i see the upgraded step from bob post ,
i already flash the TWRP recovery rom , and then try to upgrade 108k407
however , in the step 6 , i can't find "updated rkimage" from TWRP menu ,
please help me , thanks
HOW TO FLASH from SDcard
OK the stock recovery CAN flash the ROM Oman uploaded. e.g. the large IMG file.
Instructions:
1) You will need an IR remote. The one I got with the HPH works but the power button is select not the OK button.
2) download OMan's 107K4 from the posts here.
3) rename it to update.img
4) copy it to SDcard.
5) reboot into the recovery menu (using reboot app or whatever).
6) from the menu select "update rkimage from external storage".
7) It will flash the ROM then select reboot.
If you want to erase, then select factory reset before selecting reboot.
1. "stock recovery"... nothing about TWRP
2. he means something like "update from EXT" at 6)... (I think the "6) from the menu select "update rkimage from external storage"." is a copy&past issue)RK3288 Devices
Originally posted by no_spam_for_me View Post1. "stock recovery"... nothing about TWRP
and then execute the "install from zip" to upgrade ?
Originally posted by hellomysons View Postcan i rename the update.image to update.zip ,
and then execute the "install from zip" to upgrade ?Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
and then execute the "install from zip" to upgrade ?RK3288 Devices
Originally posted by hellomysons View PostHi all ,
in order to erase TWRP recovery , i wipe the data and cache partition ,
and miss operation wipe "system" partition ,
now , the box is stuck in blue Beelink logo ,
what can i do now ? is it possible to rescue my box
thanks.
If yes, I think then you are able to update with the update.img,
if not, you have to use the windows flash tool via OTG to flash the img...RK3288 Devices
i wipe my cache , data , and system partition,
and now , my tvbox stop in the beelink screen (power on screen)
i think , cause i wipe my system , so no os in the box ,
and i try the updated fw way , one and two and three ,
i still can find my device to updated ,
and then i use another normal r89 , try to use way 2 to updated ,
Another update method:
1.Power up the device,select Setting->USB->Connect to PC;
2.Deselect Setting->Developer options->USB debugging;
3.Then Click 'switch',it will go into Update Mode.
still can't found device , i dont know what i can do now ?
another problem is in following step ,
3.Plug in PSU(Power supply unit),and push and hold the button in the AV hole,then plug into the OTG cable..
i dont know what is "push and hold the button in the AV hole" , i just can push power button , no av button
please help me.
Originally posted by no_spam_for_me View PostI don't understand if you now have back the stock recovery?
There are currently 1819 users online. 1 members and 1818 guests.
