Will check Kinguser, found different information, cannot exclude malware though.
Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
You will probably get away with only flashing boot and system.
Backup anything important with titanium backup or similar, flash and then restore.
I just copy a few key apks to external sdcard and reinstall after flashing. I've flashed that often that I know the accout details I need to reenter.900Supersport
freaktab developer
Originally posted by torokmate View PostHello,
Could you check if art runtime now is working with this rom? Its not run on previous 1.8.
Thank you
If now it's working I can consider to reflash, otherwise I will wait for a possible 1.9 version!if you appreciate my efforts this is the link for any donation:
Could you maybe redo the ROM according to the comment HERE and possibly replace Superuser with SuperSU (2.06)? I also wouldn't mind updating all existing GApps to their latest version.
Also on my wishlist some cannot-do-without apps which could be placed in System or AutoInstall:
- Xposed Framework 2.7 beta1
- SystemCleanup
- MobileUncle Tools
- Lucky Patcher
- AdAway 2.91
Maybe this is something we could vote on?
Thanks for considering!
Originally posted by Poppeye View PostCould you maybe redo the ROM according to the comment HERE and possibly replace Superuser with SuperSU (2.06)? I also wouldn't mind updating all existing GApps to their latest version.
- SystemCleanup
- MobileUncle Tools
- Lucky Patcher
- AdAway 2.91
Thanks for considering!if you appreciate my efforts this is the link for any donation:
- SystemCleanup
- MobileUncle Tools
- Lucky Patcher
- AdAway 2.91
I vote for a clean rom without any additional apps!
Come on, everybody can install special apps on it's own. Just a few clicks!!!
So Brians attempt to keep the rom as clean as possible is the right way imho.
And some words about rooting (insecure boot.img and other weird myths):
Only the chainfire superSU app has some strange effects when trying to access the sd storage.
With Brians rom the root access is 100% working. So dont worry.
You don't have to fiddle around with different superuser apps.
The already implemented CWM superuser app is a very good option and it is perfect working.
Thanks chris-mm I chose superuser as its open source. I've had no problems with root access and can use titanium backup either to internal or external sdcard.
I try to keep the ROM safe and robust.
BTW my experience of the 3 sept ROM is that if you are already on 1.8 with the permissions and chrome fixes its no benefit. I see no evidence of art working.900Supersport
freaktab developer
Thanks Brian, then I'll wait for 1.9
This is the first tablet that I left a tablet with original version (only rooted and minor fixes) for such a long time! It's also the first time I see a so rock-solid first revision ROM. I'm really impressed about cube and this good device!if you appreciate my efforts this is the link for any donation:
Yes if I see anything different in this 1.8 I'll post it.
I'd become disenchanted with the rk processors they seemed that chase a quite narrow band of performance. The median devices seem far better balanced, better battery, better performance, more robust. The fact it feels quality helps too.900Supersport
freaktab developer
There are currently 2480 users online. 0 members and 2480 guests.
