Yet nothing happens I did exactly that! What do you do?
Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
[QUOTE = 900supersport; 227772] Démarrez l'outil de flash, vérifiez que vous avez sélectionné le fichier de points. Maintenant, cliquez sur télécharger. Avec la U65GT éteint connecter via USB, si vous avez installé les pilotes, puis ensuite la barre de progression doivent remplir en rouge puis plus lentement en jaune jusqu'à clignotant complet. [/ QUOTE]
Originally posted by 900supersport View PostStart the flash tool, ensure you have selected the scatter file. Now click download. With the U65GT turned off connect via USB, if you have installed then drivers then the progress bar should fill in red then more slowly in yellow until flashing complete.
Are you getting the notification sound from widows that a device has been connected? Have you installed drivers?900Supersport
freaktab developer
I've never been keen on spoofing other devices. Using market helper I've managed to install dead trigger 2 and other games. There's plenty of info around on editing build.prop to spoof other devices and its easy enough to do on a rooted device.900Supersport
freaktab developer
When you connect the u65gt you should get a notification and windows should star searching for drivers. You should select the option to choose drivers manually and select the drivers supplied in the ROM kit.
Brian900Supersport
freaktab developer
I'm almost sure that it's a problem of driver installation...if you appreciate my efforts this is the link for any donation:
You could try this and see if you can get the drivers installed
900Supersport
freaktab developer
Originally posted by 900supersport View PostYou could try this and see if you can get the drivers installed
http://singledrivers.blogspot.co.uk/...river-for.html
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Download the pdanetA4150.exe, start it and after having enabled USB debugging (on developer options) connect the cube, select make other then press install.900Supersport
freaktab developer
Have you tried changing cables and USB ports?900Supersport
freaktab developer
There are currently 1486 users online. 1 members and 1485 guests.
