Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
No you should be fine. I updated my busy box integration scripts to install to xbin rather than bin and forgot to update init.rc to match.900Supersport
freaktab developer
AW: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Originally posted by Spassknochen View PostTry this "CUBEiGation" (sorry, that was the onlyway to upload my igo, you need 7zip to extract)
It tooks over 4 hrs to upload (remember my simple, limited gsm-connection)
Link deleted by myself cause copyrights
If link doesn't work for you, please contact me!
If link work, please reupp on another hoster.
But please do it quick, because this is a free account and I think, the file is not online very long
Thank you
I think you need a windows PC...if you appreciate my efforts this is the link for any donation:
Originally posted by Poppeye View PostIMHO a much better solution for fixing any kind of Android audio deficiency is to install Viper's Audio Driver ViPER4Android FX
But there is an issue.
If I play music with the V4A and close the lid (I have the original Cube Case that's turns display oft if close) the V4A stops working and the crappy sound is back...
Do you or anybody knows a solution for that?Sent from my U65GT via chrome
Originally posted by Spassknochen View Postor put a vitual windows on your MacBook...
Originally posted by JoLander View PostI installed your version and it's starting fine. Unfortunately, I don't have any maps for this. I looked around and found a lot to download (even maps for TomTom are advised for igo) but don't know which to take. Could you point me to a location where i can find usable maps (at least for Germany to test the functionality)?Sent from my U65GT via chrome
Originally posted by Spassknochen View PostI'm using this and it is great for me.
Originally posted by ac0935p View PostThere's the option in the Phone Speaker section to "Force Enable V4A" - not sure if that's what it does and I can't find any explanation, but it sounds right (from a distance)... Try and see, I guess.
In settings there is an Option "Screen off kill"
This was activated... Now it works fine. Even if the screen turns off...
But...
Thank you very much!!!
If you wouldn't gave me the tip with the settings, I think I would not look into the settings...
Sometimes you could not see the forrest because the trees...Sent from my U65GT via chrome
Originally posted by Spassknochen View PostIf you wouldn't gave me the tip with the settings, I think I would not look into the settings...
Originally posted by ac0935p View PostGiven the issues of installing the drivers on a real windows laptop, the chances of getting them to work on a virtual machine must be pretty small... Maybe worth a try if it's the only option that you have, though.
It depends on your configuration. RAM, CPU power, OS etc...
I'm using some (PowerPC) Macs with Classic OS9 and one with 10.4 and had just a few years ago driver problems, but not this time...
Windows 7 works fine for me in a virtual environment on my PowerMac with just speed limitations.
Slower than a x86/x64 PC does, but it works on that old PowerPC Mac with OSX.
I'm using Wintel Laptops anyway, this was just for information.
Like ac0935p says:
If you're running a virtual machine, 1st see, if the cube will be recognized correctly in your flash program.
If not, DON'T TRY TO FLASH!
Go to a friend with a real Windows machine and do your flashing job there.Sent from my U65GT via chrome
Originally posted by ac0935p View PostLOL. In the good old mainframe computer days the saying was RTFM - read the f****ng manual. Now I guess its CTFS - check the f****ng settings...
Tell me, please...
Who is reading the fu*king manual?
I thought, that's the V4A is working without limits if I install.
Never saw such an option before...
Hell, Murphy is omnipresentSent from my U65GT via chrome
There are currently 3477 users online. 0 members and 3477 guests.
