Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Your guess is as good as mine re the version numbers. You can probably just download boot and android/system to the tab. I'd recommend the booting to recovery and formatting coach and data, you will then need to reinstall apps and account details.900Supersport
freaktab developer
Works fine for me, though I did format cache and data from cwm recovery.900Supersport
freaktab developer
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Originally posted by tomazf8 View Posttnx.working. a question? i saw you are extending the amount of ram. is it possible to do it on the phones as they have 1gb of ram and make it 2 gb?
Yes you cannot change the amount of RAM, you can adjust the EBR files to change the balance between data and internal sdcard.900Supersport
freaktab developer
900Supersport
freaktab developer
I use mx player, I think it's the best one!
try modifying audio decoder options, it can improve audio compatibility.
Furthermore you need to use SW or HW decoder for video (NOT HW+)if you appreciate my efforts this is the link for any donation:
MX Player is the best one, at least for me.
No sound output only when playing videos with DTS audio in HW/HW+ mode with original codec.
In settings you'll find an option to load codec needed for DTS audio downloaded from http://forum.xda-developers.com/apps...pport-t2156254
I normally use in HW+ mode(much better for battery) with custom codec loaded.
BSPlayer is also a very nice player, used in conjunction with MX Player in the past on my PiPo M9Pro..with CUBE will work only in SW Mode(battery will be discharged faster)
Cube updates all firmwares to MIUI on official page http://www.51cube.com/ch/DownList.asp?Page=1 , maybe Talk9X will get an update on next days.
going crazy
I have for android devices and noticed that on three of them I can install fifa15 and Microsoft office while on our tablet I cannot. I can live without that two app definitely. But I would like to understand why.
I tried some modifaction to the build.prop file but no result.
I then used market helper apk. Only once I was able to have compatibility with with two apps. (I used market helper to
Appear as Samsung galaxy s3)
Can anyone verify if FIFA15 is compatible with this cube tablet and in case post is build.prop?
Thanks a lot
There are currently 1874 users online. 1 members and 1873 guests.
