You can try this (copied from http://www.jellydroid.com/2014/06/ho...x-lost-imei/):
(You must have rooted your device before doing this procedure)
- Install Terminal Emulator
- Launch the Terminal Emulator app
- Type SU then press ENTER button to get Superuser permission
- After that, type this command then press ENTER button
echo ‘AT+EGMR=1,7,”IMEI_NUMBER”‘ >/dev/pttycmd1 - Last step, reboot your phone/tablet and DONE!
Or you can try this: http://www.editweaks.com/2014/08/eas...e-imei-of.html
or this: http://forum.xda-developers.com/show....php?t=2734161
You will need root access enabled for all methods to work.
PS: Do not change the root app that comes with 900supersport“s ROM... If you have changed it, reflash ROM and leave it untouched.
