Getting into recovery is really easy, just hold the power button, for about a second, then keep you finger on the volume + button. You will get a little white menu. Just use the volume up to navigate and volume - to select. I would advice to install Lepis Teamwin recovery if you can. Its really nice and alot easier to use and install modifications etc.
