Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
    Originally posted by Spassknochen View Post
    Tried it with Option "never" and the wifi shuts down in rd about 5 minutes...
    If I turn on the display, wifi will be activated in a second...
    So? That's the whole ideea.
    Always _ will be always On
    Only when connected_ will stay On only when charger is plugged in.
    Never_always will be disconnected, with/without charger .
    I really don't understand what's wrong here.
    Deep Sleep Battery Saver? For what, to turn off what is already Off? Deep Sleep is working pretty good with this tablet.
      Sorry for interrupting......
      I'm getting crazy trying to find the cracked Flash Player file that works fine combined with Dolphin Browser.
      Can anyone lend me a hand?
      Thank you.
        Originally posted by algara View Post
        Sorry for interrupting...... I'm getting crazy trying to find the cracked Flash Player file that works fine combined with Dolphin Browser. Can anyone lend me a hand? Thank you.
        Just do a google search for "android flash player apk". You will find so many links.
          Thank you.
          Got the new Nexus 5 and found that flash video playing is totally incompatible with the Android 4.4 Kitkat, no t in Dolphin, not in Firefox and other browsers. This is too bad and I can't imagine it just happened.:mad::mad::mad: I digged into...
          This one works at least with uc browser hd
            Thank you.
            Here it is https://dolphinbrowser.desk.com/cust...ayer-?b_id=317
              R: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
              Thank you.
              You don't need flash player if you use Boat Browser, no matters and very fast
                Originally posted by ac0935p View Post
                Settings->Wi-fi->Advanced->Keep Wi-Fi on during sleep
                This option does not appear to work. BetterBatteryStats reports Deep Sleep 13% but Wifi On 99%. Wifi monitor on my laptop reports that the Cube is connected all the time.
                To clarify:
                Settings->Wifi->Advanced->Keep Wi-Fi on during sleep->Only when plugged in
                Does NOT work. WIFI stays on all the time. Also checked the NEVER value and Wifi stayed on all the time.
                @Popeye - will have a go with Deep Sleep Battery Saver.
                @Edius - sorry for my original lack of clarity. I have monitored the wifi connection of my Cube for about 3 hours and Wifi stays connected all the time. The tablet does enter deep sleep, but the wifi connection must be an additional battery drain. Battery drain is definitely reduced if I turn wifi right off manually.
                I am going to monitor it again today just to confirm what happens.
                  If I'm watching my wifi connected devices with a wifi tool, the cube notifies with:
                  "shenzhen huaxuchang telecom technology"
                  Can anybody tell me, please, why the cube doesn't show his real name???!!
                  Don't know how to change the manufacturer name, but this App will at least allow you to change the device name from Android-abcdefghijklm to something meaningful.
                  I know that on my china-clone phone there was a file I edited and that changed the device name too - can't remember what the file was though, sorry - or whether the manufacturer name was in there... [So that's really useful then, NOT].
                  In my experience it's not unusual for devices to show up with strange manufacturer names. My Ainol tablet turns up with AMPAK Technology, Inc. My ZOPO clone phone turns up as AcSIP Technology Corp.
                  Who knows?
                    Display problem
                    Hi, I installed an application found on the market (Geneanet) and it does not work (display problem), that is to say that I have a dark gray screen and nothing more ...
                    Who would have a solution? Thank you.
                    Cube U65GT Talk9X 32go
                    Brian's rom and Lepi's white TWRP
                      OK, I'm an arse.
                      Monitoring wifi again today. @Edius is right; when set to "Only when plugged in" wifi turns off after about 20 minutes. I know I watched it for a couple of hours the other night and I would swear it didn't turn off then. Tech-Gremlins at play - that's my excuse, anyway.
                      {edit}Rebooted and tested again. Wifi turns off after 17.5 minutes...{/edit}
                        Originally posted by dothedew View Post
                        http://forum.xda-developers.com/show...&postcount=535
                        THANK YOU all for the different advices. Much appreciated.
                          OK so it was the build properties net.hostname (name displayed on wifi connection) and net.bt.name (name displayed in bluetooth connection). I have changed both of these values and it appears that the Cube ignores them both...
                          No trace of the manufacturer name, though...
                          {edit}using net.hostname seems to upset wifi and it takes much longer to connect to a network. I have backed out the change (since it had no positive effect anyway).{/edit}
                          Hey ho.
                            AW: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
                            Install another app that shows a white screen for some variety.
                              Hey ho.
                              Thank you, but I don't need to change it really...😉
                              I know that's my cube, but I was wondering that the Tablet doesn't show "cube" or "U65GT" in the wifi network.
                              At Bluetooth it shows U65GT.
                              Sent from my U65GT via chrome
                                Originally posted by 900supersport View Post
                                I've included instructions within the download for flashing both the full ROM (required if you are changing from Cube's earlier firmware)
                                I'm not sure what that means. If I am flashing from an earlier version of yours, also based on Cube 1.8, is that the same firmware or different firmware?
                                If it is different, why doesn't Cube give it a new version number?
                                If it is the same, why have they released it?
