Sent with Tapatalk
Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
for cube talk 9x is a different story:
now the tablet is perfectly working, 100% stable, chrome is fixed, brightness is ok, no lacks. Perfeclty usable.
It would be good to have an update to android 5.0 lollipop, but jus for curiosity and to see if the battery can last even longer (anyway battery life is outstanding as it is) with the newer power saving strategies of lollipop.if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostIt would be good to have an update to android 5.0 lollipop, but jus for curiosity...
Do i have the preloader file checked when flashing this ROM?
A bit concerned due to reading on other sites that flashing the preloader when restoring a ROM will brick device.
The instuctions included dont say not to flash this file, and havnt seen mention of it.
So do i flash with preloader?
Originally posted by hijack View PostDo i have the preloader file checked when flashing this ROM?
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Used the ROM but still problems
Hi guys,
Ive received my Cube 2 week ago and ive updated it with this ROM.
I have 2 problems with the CUBE.
1. Internet doesnt work after tablet wakes up from standby. Only opion is to switch WIFI option off and on again. (problem is not caused bye the ROM, it had the problem out of the box)
2. GPS doenst work anymore after the update.
Could you help me with this please? Thanks in advance!
Brian900Supersport
freaktab developer
It won't do any harm. I think formatting data from recovery should be enough. All apps and settings will then need setting up from scratch following this.
Brian900Supersport
freaktab developer
AW: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Originally posted by 900supersport View PostIt won't do any harm. I think formatting data from recovery should be enough. All apps and settings will then need setting up from scratch following this.
Brian
@nl1982
Power off the device till brief vibration. Then press power for 1 second, release it and quickly hold vol+ until recovery appears. I recommend TWRP.
sent with my Cube Talk 9x U65GT
Originally posted by Dr. Evil View PostIt dit clear cache and data only. Result is I don't get a Sat fix anymore. With the former ROM I dit. I'll try clearing Dalvik though, otherwise do a fresh flash.
@nl1982
There are currently 3269 users online. 2 members and 3267 guests.
