Did you choose the correct EBR1 and EBR2 files?
Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Originally posted by hawky View PostIs it pro version because I haven't that option in security paragraph ...
I had supersu v2.02 and their was no namespace option, but after updating to v2.14 the option was available.Last edited by hijack; 26 October 2014, 09:12.
Originally posted by JoLander View PostNow the important part:
In the SuperSU settings you have to uncheck the option 'Mount namespace separation' and reboot the tablet.
Now all is working very well and I can backup/restore with titanium without any problems.
Originally posted by eteles View PostAre you restoring from internal memory or external? You may have a problem with your storage... Try changing external sdcard...
Can somebody explain the use of these different EBR files?
And what to choose?
ThnxLast edited by skippie; 26 October 2014, 10:56.
AW: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Originally posted by giouncino View PostI did exacly what you explained as soon as I installed superSU update more than one month ago!
anyway thanks you for explanation could be useful for other users.
Supersu is working perfectly.Last edited by Poppeye; 26 October 2014, 11:53.
Hm, a weird thing has happened. This morning, all apps complained they do not have root access anymore. I have not tampered with the default superuser.apk since I installed this ROM some weeks ago.
Now I'm not sure what happened, either the ROM has mysteriously become unrooted or the superuser cache is corrupt, which I cannot delete without root since it's a system app.
What should I do? Do you guys have a link to the superuser.apk that was used in this ROM as a zip so I can try flashing it fom recovery again?
UPDATE:
Never mind, after rebooting the tablet I seem have root once more. Still, I'm still feeling a little uneasy now.Last edited by Poppeye; 26 October 2014, 12:17.
Originally posted by skippie View PostI tried internal and external memory and I didn't change the EBR, left it like it was
And what to choose?
Thnx
Originally posted by eteles View PostI think everybody have the same problem... Can't verify scores in Antutu (shows in RED). I have not found a fix for that.
It's not recommended to use a much "bigger" charger for faster charging... This can permanentely damage your battery and even your tab (if battery blows up)... If you don't like the stock (crappy) charger, you could buy Onda's original charger on banggood.com for about U$ 8. It's 2.5A and good quality.
please about the patch brightness can you tell me more what is it exactly for and how can i check on my tablet if it works after install it ?
thanks again
Originally posted by enay View Postthank you but does this charger fast charge the tablet better than the stock one (short time )?
thanks again
Originally posted by eteles View PostMinimum brightness of the tab is too high (about 30%) and makes it uncomfortable to be used in the dark... The brightness patch changes the minimum value to 4%, to make it more comfortable to be used in the dark... Or if you want to save battery, for example.
I have already install the patch
please how can I check if it is install correct?
Originally posted by eteles View PostUse the tab in the dark with lowest brightness... If the light is confortable, then, the patch is installed.
thanks a lot for your help
GPS wont work anymore....Tablet isnt able to establish my position
Please i have a GPS issue it does not work does any body had same problem ?
How to fix it please?
Originally posted by skippie View Postanyone got Youtube / flash player working ?
Update : working with a new version of YouTube.
Download link -
or you go through the archives here:
I even use YouTube through Chrome. It works with this Flash Player installed. Make sure you use the "desktop site" and enable the HD settings. Hope this helps.
There are currently 1469 users online. 0 members and 1469 guests.
