Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
You can try greenify, it could help youif you appreciate my efforts this is the link for any donation:
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Originally posted by nikos-s View PostI finally find it, it is the sixaxis controller for the joypad who running on the background.
Do you know any program which allow me to control and deactivate programs from running when i start the tablet?
Feedly APK
Originally posted by pennred View PostCan you upload your ready compiled Feedly.apk to dropbox or here in forum please.
I've uploaded the edited apk into dropbox here.
Let me know if you can access and download the file from there since dropbox and myself are not best friends and not sure if I'm doing things as I'm supposed to.
One thing I've noticed with this edited version is that the navigation is not as smooth but the black squares are gone!
Originally posted by ammo2003 View PostHey Everyone.
Got my cube today and I am going to flash this rom. The drivers have been installed already in my pc.
Question is :
1. For a full flash , do I check all the boxes in the scatter loading, or do I uncheck preloader and tick all the other boxes?
Thanks !
Just need to select EBR 1 and EBR 2 of same size (I used 6gb on my 32gb version) and select which recovery to flash (you can get TWRP from the lepi thread, there is also a great boot animation there that you can easily intall using TWRP/CWM).
After you have recovery, use it to wipe data and cache and that's it, done
cube talk 9x drivers
Hi Mr Devil
I am running windows 7. on device manager it says 'Media Tek DA USB VCOM Port (COM12)' also 'Media Tek PreLoader USB VCOM Port (COM13)'. i tried loading the drivers. then i get a message error code 10.
Is there no easier way of updating the firmware on cube talk 9x?
Originally posted by Dr. Evil View PostAre you on Win 8? In that case you've got to deactivate driver authentification first.
sent with my Cube Talk 9x U65GT
If it didn't flash, then open device manager and connect tablet (while powered off) and watch device manager for a new device to appear on the list. When it appears right click on it quickly (before it disappears again) and select install manually and select path to driver.
I only had to do it once so having trouble remembering what showed up in device manager but I'm sure it was the " Mediatek Preloader USB".
Originally posted by yungwizzy View Posthi i dont have a pc , is there any way i can flash the rom on my cube and my cube locks by its self when am on landscape for long any solution for that?
As for this ROM, I think you need to flash it from pc
Lepi's ROM can be installed using CWM or TWRP on the tablet alone.
I think you will need to root tablet using superuser or super SU (from p!aystore)
And then install CWM or TWRP (from play store) so you can boot to recovery to install it.
Someone who has done it that way may offer more accurate instructions.Last edited by hijack; 04 November 2014, 16:33.
Hi, just today recieved my Talk 9x, so far considering what I paid for it, I am VERY pleased with itThe first thing I did was flashing this ROM (well okay, I tried the stock rom for a few minutes)
Just got some questions, any apps/mods to tweak the sound quality?
Any other performance tweaks/tips you guys could suggest, like disabling some startup items as mentioned (but which ones?) and other tips?
About the screen, if I hadnt read about the "grainy" issue, I wouldnt have noticed anything, but mine is 16GB white version and it seems a bit grainy, but I strongly belive its the protector thats causing it (havnt removed the protector yet, should I remove it and maybe order something better for replacement?). But dont get me wrong, im definately NOT complaining about the screen
There are currently 1861 users online. 0 members and 1861 guests.
