so sending tablet back is really the only solution?
Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
AW: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
This helped me solving the GPS problem: If you're rooted, install FASTERGPS first and select the region nearest to you. Restart. Install GPSTest from Play Store, select keep screen on in options, go outside, activate GPS and WLAN, select clear GPS in app and wait for about 2 - 3 minutes. This should give you the first fix and afterwards it will be much faster.
Originally posted by tempdroid View PostThis helped me solving the GPS problem: If you're rooted, install FASTERGPS first and select the region nearest to you. Restart. Install GPSTest from Play Store, select keep screen on in options, go outside, activate GPS and WLAN, select clear GPS in app and wait for about 2 - 3 minutes. This should give you the first fix and afterwards it will be much faster.
Originally posted by Thomascz65 View Postok, i would give it a try. But i assume you could find atleast low signal before you even did that, or you couldnt find any at all aswell?
Originally posted by tempdroid View PostNo, there wasn't any signal before and 13 afterwards.
How about this for gps https://play.google.com/store/apps/d...m.chxdev.mtgpssamsung note 3 n9005 snapdragon [email protected] GHz|cube u65gt talk9x
Ask about stylus
Hi all.. It's been a while since I kept track of this thread.
It seems that fellow U65GT users are increasing.
Nice!
There is something I need to ask :
- Has anybody tried using capacitive stylus? I bought myself a stylus to take a note and drawing, but I cannot use it to the cubetalk tablet.
I have to push really hard, and still it's not responding all of the touch.
Is there any way to use stylus?
I have no problem using the touchscreen by finger, though. Very fluid and responsive when I click and swipe..
When I tried to use the stylus to my Sony Z2 phone, there's no problem at all.
- I love to play PvZ2 games, and it needs me to hold the screen to place the plants (dragging touch).
Many times, when I drag the icon, it stopped at the place I didn't intended to.
The point is, I need to press the screen a little more harder compared than when I use my Z2 phone, so my dragging can be accurate and not misplaced in the middle of the drag.
Is that normal?
Is there any way to improve the sensitivity of the touchscreen?
I feel there's a difference of the touchscreen response at my Cubetalk
compared with other branded devices, and I hope there's some way to make it better.
The dragging problem is not a big problem though, just for gaming matter.
I used this tablet primarily for working reasons, so the stylus problem is the one matter that's been bothering me more.. LOL.
Have u guys noticed and experienced these problems?
remove the screen protector if you haven't yet done so.
touch response is very good.samsung note 3 n9005 snapdragon [email protected] GHz|cube u65gt talk9x
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Originally posted by Coalescence View PostMany times, when I drag the icon, it stopped at the place I didn't intended to.
Is that normal?
I found that touching the end of the stylus on my tongue before using it helped to make it more accurate.
Sounds funny, I know, but I think with a little moisture on the tip, helps the screen register the touch better.
There are currently 3122 users online. 2 members and 3120 guests.
