One last question: after you flashed ebr1 and ebr2, did you do some kind of factory reset or clear cache or maybe needed to format new EBR1/EBR2 partition or something similar? Or did you just rebooted the tablet and there was no need for anything else?
Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Originally posted by gdp77 View Postthank you.
Would you be so kind to provide me a link for firmware v2.0_20141111?
Also does anyone know if I can keep the stock rom and only flash with SP flash tool ebr1 and ebr2 from supersport's rom in order to increase my app storage?
V2.0: http://www.freaktab.com/showthread.p...or-CWM-or-TWRP
V2.01: same link as post #107
Originally posted by Freewaymad View PostHere are couple of other links for Lepi's V2.0 and V2.01 ROM's. These are very good. Make sure you follow the instructions.
Lepi's links are 20141115 and 20141215
Originally posted by gdp77 View Postthank you, but I am looking link for 2.0_20141111
Actual link: http://www.51cube.com/ch/DownShow.asp?ID=292
Discussion here: http://www.freaktab.com/showthread.p...nk-to-V2-0-ROM
Read carefully.
Hope this helps.
Originally posted by gdp77 View Postthank you for your help.
One last question: after you flashed ebr1 and ebr2, did you do some kind of factory reset or clear cache or maybe needed to format new EBR1/EBR2 partition or something similar? Or did you just rebooted the tablet and there was no need for anything else?if you appreciate my efforts this is the link for any donation:
you need to modify the kernel, but if you do that you can:
- lead to instability
- overheat
you need to pay attention,
I was able to do that mod on my ex-Pipo tablet, but it was impossible to me to mod frequency AND more important voltages on our cube talk 9x. I don't know ho to mod cube kernel...
It's a real pity!if you appreciate my efforts this is the link for any donation:
Originally posted by Relles View PostSave me trolling all though this thread and the forums could someone please link me a download for the 4g partition pls.
By default scatter file will poimt to 4GB...is your choice here. Don't forget to flash custom CWM recovery from the same ROM folder.
There are currently 3457 users online. 0 members and 3457 guests.
