Sent from my U65GT using Tapatalk
Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
do not do that!
if you set "downolad + format" option YOU MAY LOSE YOUR IMEI!!!
It is better to use "download only".if you appreciate my efforts this is the link for any donation:
Hi!
I had flashed U65GT_V1.8_20140903. in 95 % was "error brom error s_ft_download_fail (4008)"
after some experments SP flash tool stops on 0% with the same error "brom error s_ft_download_fail (4008)"
I think now problem is with battery. befor flashing tablet was charging good but now its problem.
may be i had flashed or ersed samthing wrong and its broke charging.
is way to charge batery in other way or repair broken stuff?
Maybe i need manualy charge batery and then flash rom?
sorry for may english
p.s. in recowery mode when tablet conect to laptop in devices and printers i see device "full" (2 disk drives) but can not open
Which version do I have at present?
I'm happy with the setup I have now, but I'm not entirely sure what it is!
Can anyone tell me if this indicates which firmware I have?
Model number
U65GT
Android version
4.4.2
Baseband version
MOLY.WR8.W1315.MD.WG.MP.V39.P1.2014/06/18 16:45
Kernel version
3.4.67
zmchivin2@civin-All-Series #1
Tue Sep 2 13:42:24 CST 2014
Build number
0502L012_EP79-U65GTB1BMXXTDC_V1.8_20140902
Originally posted by jiggaman View PostI already backuped my imei; but when i flash again the rom from flash tools, should I flash the fixes too(6 gig app partition, light 4%....)?if you appreciate my efforts this is the link for any donation:
I just received my cube talk9x u65gt (16GB, v2.0_20141111).
I have some questions:
1) Will it be ok to flash supersport's rom, even if it is based on 1.8 firmware?
2) The latest supersport's rom is the one at the #1 post of this thread or there is an updated link somewhere else ?
3) Is there any way to make a full backup of my tablet (including stock recovery) before I try to flash a custom rom? I would prefer a full backup without rooting the tablet, so I can bring it back to factory status if I need to.
thanx in advanceLast edited by gdp77; 03 January 2015, 14:28.
Originally posted by gdp77 View PostI just received my cube talk9x u65gt (16GB, v2.0_20141111).
thanx in advance
Answer to 2 is yes, at the first post.
Answer to 3 would be to just download the stock ROM. That would be your best bet.
Hope this helps.
Hope this helps.
Would you be so kind to provide me a link for firmware v2.0_20141111?
Also does anyone know if I can keep the stock rom and only flash with SP flash tool ebr1 and ebr2 from supersport's rom in order to increase my app storage?
here is stock V.2.0:
and yes, on stock rom you can install EBR1 & 2 to increase app space, but you need to take a backup of pictures (you will lose them)if you appreciate my efforts this is the link for any donation:
My stock rom is v2.0_20141111, not 1.8
Can I still flash ebr files from supersport's rom (based on 1.8)? Do I need to root?
Yes, I did exactly the same, and you don't need to be root for thatif you appreciate my efforts this is the link for any donation:
There are currently 4433 users online. 0 members and 4433 guests.
