hoping new rom will fix the wifi issue, anyone else have similar, loose signal in standby mode?
Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Originally posted by Edius View PostIn this ROM folder you'll find different EBR1 and EBR2 for 2,4 and 6 GB partition.
By default scatter file will poimt to 4GB...is your choice here. Don't forget to flash custom CWM recovery from the same ROM folder.great you made it possible to install with the SP Flash tool )
Originally posted by Relles View PostYeah installed this rom again and then realised you can choose your app space from the flashrom but TBH im happy with the 2g, I dont install massive amounts of apps and I would rather have the extra space for books etc. Only problem I am having is trying to find that chrome fix, Ty again though for linking the touchscreen fix rom from your G drive, havnt seen that rom linked anywhere else with the flashrom installer,and if I would have downloaded form cube it would have taken forever and i couldnt have installed it anyway as i think as the install method required the use of touchscreengreat you made it possible to install with the SP Flash tool )
It is very easy to use. Just unzip and follow the "help.png".
Hope this helps.
some touch screen glitches
i have some troubles with touch screen of my black 32gb cube talk.
sometimes it happens that i the screen loses sensitivity and maybe doesn't recognise my touch, very easy to check swiping on the keyboard, it often loses the "track" and splits the word you wanted to write in different ones. or also in browser scrolling pages: sometimes loses the touch and find it again, making the page suddendly and almost instantly scroll to the end... does this happens also to some of you?
it is not so terrible, doesn't always happen, but i ask myself if it's just mine or all like that
i'm sure it is not because of the rom, i just ask if you people have same troubles too or if it is mine somehoe defective
Originally posted by lothian77 View Posti have some troubles with touch screen of my black 32gb cube talk.
I suggest you to use greenify app to lock useless processes.if you appreciate my efforts this is the link for any donation:
Also my tablet has "slowed down". The wait to load web pages on any browser is getting painfully slow.
Thinking of a factory reset. Any other recommendations?
There are currently 2968 users online. 0 members and 2968 guests.
