Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Originally posted by fokemon View PostI have been tuning my volumes with MTK engineering tool. There was a need, couldn't hear a thing at some moment... Now it is fine!
@espa
fokemon already wrote the app's name, you find it on the Play store. Alternatively, there's a numeric combination code to access the eng.-mode without installation of the app.
Originally posted by Farmer_General View PostFigured I'd chime in with my first post. The last supported version of flash for android works fine on my cube. I use Firefox for my browser.
Look at this official Adobe Page regarding the Flash Player and Android:
I used the last version that was put out by Adobe before support ended and all works fine. Hope this helps!
By the way thanks for the great Rom Supersport! Been using it for 1 month now without any problem. Xposed Framework and Gravity Box do wonders to add customizations close to Cyanogen Mod.
Will a fix ever be released for what Supersport said was the broken "init d support". I think that's what he called it.
Thanks again Supersport!!
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Originally posted by tomazf8 View Post@900Supersport i have flashed your rom, now i want to send my u65gt to repair to china regarding to bad biuld quality and speaker problems. do i need to replace the rom with the original before that? anything else?900Supersport
freaktab developer
Vs: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Originally posted by yungwizzy View PostAnybody knows how to save large hd games on SD card ??samsung note 3 n9005 snapdragon [email protected] GHz|cube u65gt talk9x
Originally posted by yungwizzy View PostI don't understand
In order to use part of your external sd card for application installations you need to partition (or separate a portion of said card into another "drive ") the sd card and format said section as ext2 which is a secure partition for android as well as Linux /Unix.
The remaining space on your sd card not used by the partition will remain as it was , only smaller by the size of your new partition.
Search for the application our friend mentioned and it will explain more.
Hope this long winded explanation helps, my friend.
Originally posted by eteles View PostForget about partitioning SD card. Use foldermount. Search google how to configure it to make a folder in the internal storage point to another folder on external storage.
There are currently 2282 users online. 1 members and 2281 guests.
