Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Hi 900supersport
Just wanted to say I like what you have done with the ROM. To visually enhance the rom I used the xposed framwork to add some eye candy. I also use the Google launcher with icons from MIUI. Just wanted to share a few screenies with the folks here, hope you like them. Keep up the good work 900supersport, hope to see further updates in the future.
Thanks.
No network!!
Hi everyone,
Since install of this ROM I can't get network on my Cube.
I was using a previous version and it was working fine. The SIM card is recognized but no network available.
Re-installed the previous version but still no joy...
Tried two different SIM's one UK and one PT.
Any idea why this is hapenning?
Thanks in advance
Thanks in advance
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Originally posted by jrgcorreia View PostIt shows unknown IMEI...can anything be done to get it back?
Thanks for your reply!
Enable USB debugging on developer settings, connect tab to PC, open MTK Droid Tools, click ROOT button, allow root access on tab screen, click IMEI button, inside IMEI1, write your IMEI confirm and reboot...
You have to know you IMEI for this to work.
Originally posted by mattiesrag View PostFound "REBOOT MANAGER" on Playstore. Works really well and gives many options including boot to recovery. Give it a try! Certainly made my life a lot easier. Regards
Originally posted by eteles View PostYou can easily restore your IMEI using MTK Droid Tools...
I didn't have a backup for the IMEI but managed to find it on the Google's Dashboard...
I'm just not being able to download MTK Droid Tools has all atempts were blocked by my anti-virus...Does anyone knows where can I download it safely?
Originally posted by ac0935p View PostOr you can just use Mobile Uncle Tools or ROM Manager Lite... Or install xPosed and GravityBox[KK] that allows you to add items to the power menu. Or...
This is all new to me, so I must thank all of you for your help!!
mtk tool
mtk droid tools is a root tool.turn off antivirus and use this tool.there are no virus in this tool.
I guess I might be doing something wrong....
There are currently 2011 users online. 0 members and 2011 guests.
